Full Version: Moi3d obj export question
Show messages: All  1-3  4-6
7 Jan   [#4]
Something very easy to make! :)
Draw a line as any measure you want!
Say 1 meter
Import your OBJ
Transform / Oriente/ Line - Line
4 cllicks et voilĂ ! :)
7 Jan   [#5] In reply to [#3]
Hi Matadem, what are you using for the .obj import back into MOI?
If it's Max Smirnov's _ImportObj script, that resizes the import by default.
To stop that add a parameter "exact" to the command in your keyboard shortcut.
So set up the shortcut like this:
_ImportObj exact
7 Jan   [#6]
I have created a cube 10x10x10cm
I have exported as obj and imported in back with both Max import obj and create subD and both are imported just fine. right size.
weird but it works ...so now I have to look at Nvil3d import settings...
almost there..
As I tried other shapes came up with some weird measurements(50cm come in at 14.7cm)....used the import exact...came in at 100x smaller..
so I upped the export 100x in Nvil3d and it seems to open in Moi good.
Tnx!
