Full Version: pises and structures
Show messages:  1-4  5-23
4 Jan   [#5] In reply to [#2]
hii
this what i need.. thank u alot.. tell me where can i download and install all plugins scripts like u
4 Jan   [#6] In reply to [#5]
Hi 4rw1n, there are some links on the resources page:
https://moi3d.com/resources
Look for "Burr's script archive", "Petr's MoI page", and "Max Smirnov's MoI scripts".
Instructions for installing a script here.
4 Jan   [#7] In reply to [#6]
how to add like this
4 Jan   [#8] In reply to [#7]
"""""""how to add like this"""""""""
That is Max Smirnoff custom UI
You can find it in links Michael posted
Mine is a bit customized. But only to add other things, the default one will give you the commands list
4 Jan   [#9] In reply to [#8]
i just install there alot options i dont like.. i want like ur simple but good.. of course if not problem to share
4 Jan   [#10] In reply to [#9]
Should be able to get what you want by going to appdata directory and looking for startup folder and find the list of CustomUI stuff in there...
Put a minus character at the beginning of any entry you want to not show up in that list, like this
-99 LogScroll.js
Message 11891.11 was deleted
4 Jan   [#12] In reply to [#10]
Just a quick note on the appdata folder. By default the appdata folder (on Windows) is at %AppData%\Moi .
In the config Burr shows above he's made an appdata folder inside the install folder c:\Program Files\MoI 5.0 beta Sep-17-2025\appdata which is an optional way to set things up to make a "portable" version that has everything contained inside one folder.
6 Jan   [#13] In reply to [#3]
BurrMan is a very diplomatic:
Feel free to come back with more Q&A and help with using MoI and how to model with MoI and get things done in MoI.
I don't always have this quality:
I don't understand why you so often advertise other software when there are often solutions with MoI.
What's more, you're lucky enough to have a French forum just for you.
6 Jan   [#14] In reply to [#13]
I don't believe that Burrman message was for me !
Look at the Number of its message adress! ;)
About the other free progs for go inside Moi I have always made that since quasi 20 years! :..
6 Jan   [#15]
Hmm. No time to think about the implementation, but it seems like it should be relatively easy to built that assembly as a set of curves describing the centerline of each tube. Give each tube thickness a different color, then run a script that sweeps a circle of that size along each curve. Do a few boolean operations afterword and you should have clean joints — possibly with some caveats when you're dealing with multiple pipes joining in a single spot. Keep the original curves around and if the frame geometry changes you can regenerate the pipe version.
7 Jan   [#16] In reply to [#14]
4rw1n > Im drawing the chassis of a buggy. But I can't easily draw the chassis in MOI. I mean, I can draw it, but it's not easy and it's not correct; it's difficult to connect the points.
- Here he explains his problem, his difficulties.
4rw1n> Is there something similar in MOI 3D?
- Here he clearly expresses his request.
For me, he wants to create his buggy frame with MOI 3D.
BurrMan >,Ask for help using MoI, modeling with MoI, and completing your projects in MoI.
- But then again, maybe it was just MoI (me) who saw a little message in it.
I looked for a buggy frame design similar to 4rw1n's, but couldn't find anything satisfactory. So I'm going to use 4rw1n's image to create the buggy frame with MoI3D, just for fun.
7 Jan   [#17] In reply to [#16]
“”””””” maybe it was just MoI (me)””””””
Lol….
Welcome to Pleiades!
8 Jan   [#18] In reply to [#16]
hey man.. if u want i can send u org file u can recreate itd.. and send us here...
i want make it full here how will look.. but i dont alot of time..
8 Jan   [#19]
Excellent!
9 Jan   [#20] In reply to [#18]
Yes, you can send it in a private message or directly on the website.
Best regards.
11 Jan   [#21]
thank u guys now look perfect
12 Jan   [#22] In reply to [#21]
Hi 4rw1n,
@ thank u guys now look perfect
Totally with MoI3D?
13 Jan   [#23] In reply to [#22]
yes its make over script in moi ..very easy and helpfull
