Full Version: pises and structures
Show messages:  1-13  14-23
6 Jan   [#14] In reply to [#13]
I don't believe that Burrman message was for me !
Look at the Number of its message adress! ;)
About the other free progs for go inside Moi I have always made that since quasi 20 years! :..
6 Jan   [#15]
Hmm. No time to think about the implementation, but it seems like it should be relatively easy to built that assembly as a set of curves describing the centerline of each tube. Give each tube thickness a different color, then run a script that sweeps a circle of that size along each curve. Do a few boolean operations afterword and you should have clean joints — possibly with some caveats when you're dealing with multiple pipes joining in a single spot. Keep the original curves around and if the frame geometry changes you can regenerate the pipe version.
7 Jan   [#16] In reply to [#14]
4rw1n > Im drawing the chassis of a buggy. But I can't easily draw the chassis in MOI. I mean, I can draw it, but it's not easy and it's not correct; it's difficult to connect the points.
- Here he explains his problem, his difficulties.
4rw1n> Is there something similar in MOI 3D?
- Here he clearly expresses his request.
For me, he wants to create his buggy frame with MOI 3D.
BurrMan >,Ask for help using MoI, modeling with MoI, and completing your projects in MoI.
- But then again, maybe it was just MoI (me) who saw a little message in it.
I looked for a buggy frame design similar to 4rw1n's, but couldn't find anything satisfactory. So I'm going to use 4rw1n's image to create the buggy frame with MoI3D, just for fun.
7 Jan   [#17] In reply to [#16]
“”””””” maybe it was just MoI (me)””””””
Lol….
Welcome to Pleiades!
8 Jan   [#18] In reply to [#16]
hey man.. if u want i can send u org file u can recreate itd.. and send us here...
i want make it full here how will look.. but i dont alot of time..
8 Jan   [#19]
Excellent!
9 Jan   [#20] In reply to [#18]
Yes, you can send it in a private message or directly on the website.
Best regards.
11 Jan   [#21]
thank u guys now look perfect
12 Jan   [#22] In reply to [#21]
Hi 4rw1n,
@ thank u guys now look perfect
Totally with MoI3D?
13 Jan   [#23] In reply to [#22]
yes its make over script in moi ..very easy and helpfull
