Full Version: pises and structures
Show messages:  0-19  20-23
3 Jan   [#1]
hi
im back after 7-8 years :)
im drawing the chassis of a buggy. but not easy for me draw chassis in moi. means i can draw but not easy and not correct hard to connect points
Is there anything similar in moi 3D? The best way to draw pipes and structures like on video
https://www.youtube.com/watch?v=iqwweb6prTI
3 Jan   [#2] In reply to [#1]
Gonna want to create pipes to punch into the other pipes. Note the 2 different sizes.
4 Jan   [#3]
You can also use the free TopMod for made crazzy structure then Import it inside Moi3D
https://people.tamu.edu/~ergun/research/topology/download.html
Not exactly tubes but...
With the native SubD from File
or By ImportOBJ + _SubDBeta9 by Max Smirnov
https://moi3d.com/wiki/MaxScriptArchive
4 Jan   [#4] In reply to [#1]
Feel free to come back with more Q&A and help with using MoI and how to model with MoI and get things done in MoI
4 Jan   [#5] In reply to [#2]
hii
this what i need.. thank u alot.. tell me where can i download and install all plugins scripts like u
4 Jan   [#6] In reply to [#5]
Hi 4rw1n, there are some links on the resources page:
https://moi3d.com/resources
Look for "Burr's script archive", "Petr's MoI page", and "Max Smirnov's MoI scripts".
Instructions for installing a script here.
4 Jan   [#7] In reply to [#6]
how to add like this
4 Jan   [#8] In reply to [#7]
"""""""how to add like this"""""""""
That is Max Smirnoff custom UI
You can find it in links Michael posted
Mine is a bit customized. But only to add other things, the default one will give you the commands list
4 Jan   [#9] In reply to [#8]
i just install there alot options i dont like.. i want like ur simple but good.. of course if not problem to share
4 Jan   [#10] In reply to [#9]
Should be able to get what you want by going to appdata directory and looking for startup folder and find the list of CustomUI stuff in there...
Put a minus character at the beginning of any entry you want to not show up in that list, like this
-99 LogScroll.js
Message 11891.11 was deleted
4 Jan   [#12] In reply to [#10]
Just a quick note on the appdata folder. By default the appdata folder (on Windows) is at %AppData%\Moi .
In the config Burr shows above he's made an appdata folder inside the install folder c:\Program Files\MoI 5.0 beta Sep-17-2025\appdata which is an optional way to set things up to make a "portable" version that has everything contained inside one folder.
6 Jan   [#13] In reply to [#3]
BurrMan is a very diplomatic:
Feel free to come back with more Q&A and help with using MoI and how to model with MoI and get things done in MoI.
I don't always have this quality:
I don't understand why you so often advertise other software when there are often solutions with MoI.
What's more, you're lucky enough to have a French forum just for you.
6 Jan   [#14] In reply to [#13]
I don't believe that Burrman message was for me !
Look at the Number of its message adress! ;)
About the other free progs for go inside Moi I have always made that since quasi 20 years! :..
6 Jan   [#15]
Hmm. No time to think about the implementation, but it seems like it should be relatively easy to built that assembly as a set of curves describing the centerline of each tube. Give each tube thickness a different color, then run a script that sweeps a circle of that size along each curve. Do a few boolean operations afterword and you should have clean joints — possibly with some caveats when you're dealing with multiple pipes joining in a single spot. Keep the original curves around and if the frame geometry changes you can regenerate the pipe version.
7 Jan   [#16] In reply to [#14]
4rw1n > Im drawing the chassis of a buggy. But I can't easily draw the chassis in MOI. I mean, I can draw it, but it's not easy and it's not correct; it's difficult to connect the points.
- Here he explains his problem, his difficulties.
4rw1n> Is there something similar in MOI 3D?
- Here he clearly expresses his request.
For me, he wants to create his buggy frame with MOI 3D.
BurrMan >,Ask for help using MoI, modeling with MoI, and completing your projects in MoI.
- But then again, maybe it was just MoI (me) who saw a little message in it.
I looked for a buggy frame design similar to 4rw1n's, but couldn't find anything satisfactory. So I'm going to use 4rw1n's image to create the buggy frame with MoI3D, just for fun.
7 Jan   [#17] In reply to [#16]
“”””””” maybe it was just MoI (me)””””””
Lol….
Welcome to Pleiades!
8 Jan   [#18] In reply to [#16]
hey man.. if u want i can send u org file u can recreate itd.. and send us here...
i want make it full here how will look.. but i dont alot of time..
8 Jan   [#19]
Excellent!
9 Jan   [#20] In reply to [#18]
Yes, you can send it in a private message or directly on the website.
Best regards.
