Full Version: smoother lofting?
Show messages: All  1-16  17-19
3 Jan   [#17] In reply to [#16]
Understandable....
Have fun Rusty!
3 Jan   [#18] In reply to [#16]
And no doubt that someone will make a Naca dynamic modeling with Elephant! ;)
3 Jan   [#19] In reply to [#7]
"""""""""""""There are settings to change the thickness of the blade at the root and tip, then another slider for the curve between those"""""""""""""""""""
These 2 values actually relate to each other mathematically in airfoil design. The changes have to be planned.
Changing the chord length from 1 station then back again right After it within just 3 stations will be a no no....
You can check your chord lengths. They usually taper from root to tip.
I think the trick is to choose a "ratio" as a percentage of lift coefficient, then stick to that as you change the thickness or chord length (Or Both)
Choosing this chactoristic allows you to pick and choose a change you want, but maintain the aerodynamics as you go...
