Full Version: Hemispherical dome design ?
Show messages: All  1-3  4-5
29 Dec 2025   [#4] In reply to [#3]
Hi Sven,
> Curious if I should be able to create an arc on surface ?
Using which command, do you mean with Draw curve > Arc > Center?
The arc center point draw command is focused on drawing an arc on a plane. If you pick the arc center point on a surface it will use a drawing plane with the plane origin on that point and a z axis along the surface normal.
So the arc will be on a plane something like this:
That tool does not know how to draw the entire arc on a surface because that is only possible in special cases.
But I think arc through 3 points will do it if you put the 3 points all on the sphere surface.
29 Dec 2025   [#5] In reply to [#4]
Thanks for center arc explanation because it now makes sense based on what was happening. With the addition of 3rd "on" point on the surface the 3 pts arc works.
Sven
