Show messages: All
1
2-13
Maybe like this
Draw Rectangle
Draw Arc
Select All
Separate (in fact only rectangle)
Erase one Curve
Select All (no need to Join)
Extrude
Erase / Hide ... start curves if you want only alone Solid (not shown on the video)
Never mind. The curve I drew was a tiny bit out of plane, so I didn't see it. Making the curve planar to the rest of the rectangle works fine in extrusion.
Delete my second post--I went to front view, redrew the shape, and it still has the problem.
Frenchy, your method works fine. The difference is using separate instead of trim. I must be leaving some bit of rectangle nature.
Thanks!
This is really odd. Sometimes it works, sometimes it ignores the arc. I'll have to poke at it awhile, I must be doing something different when it works.
Hi sos, if you get another case where it's not working as expected please post the .3dm model file here or e-mail to
moi@moi3d.com so I can take a look at it.
Thanks, - Michael
My problem posting images is Firefox. There, when composing a reply I only have three buttons: Post Preview Cancel.
I have switched to Vivaldi, where I also have the Attachements button. Someday soon I'm giving up on Firefox.
I did a set of different radius curves (attached). For shallow curves, the curve is ignored. Deeper curves and I get a straight approximation to the curve (in the solid). 3dm attached.
frame.3dm
That's likely a display mesh approximation limitation, if you export it (with a forced divided larger than at 2 or less), those arcs seems correctly evaluated.
You can change the mesh angle display in the display option, but even with a tiny angle it wont be as good as the mesh export.
Also if you want a more accurate display, you can maybe rebuild the arc (rebuild command here with 10 points), that should trick the mesher.
(I'm not sure if you still have a perfect math arc doing so ?)
Hi sos, yes like PaQ writes above that's just a display artifact. It's best to just ignore it.
Also some previous discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10950.2
This makes tons of sense. Thank you.
Steve
Hi sos,
I have been a Firefox user and member of the Moi3D forum for many years. I have never encountered any problems when communicating, or when sending images or files as attachments. I therefore don't think the problem is with Firefox.
Show messages: All
1
2-13
