Show messages: All
1-4
5-8
Or another possibility is to do the chamfer along the entire area, then boolean union the end part so you have this:
Then if you copy this edge over:
You can then make a cylinder with Construct > Revolve:
Then boolean difference using the cylinder as the cutting object:
Michael.
I tried your first trick to get the right chamfer easily enough, but I can't get my head around what you did in your second example, Could you do a short video showing how things are orientated and how you placed the axis of rotation for the cylinder, please?
Martin.
Hi Martin, I selected the edge and then ran the Transform > Copy command.
For the base point I clicked on the chamfer surface that is near the edge, then used surface normal snap to some distance away, looks like this:
Thanks, Michael.
The video was most helpful. MoI's incredibly powerful snap & construction line combination is just great in all sorts of ways.
Martin.
Show messages: All
1-4
5-8
