Show messages: All
1-2
3-8
The issue it where the chamfer ends I want it to taper back to the 90deg edge as in the photo without the blue question mark.
Hi GuyLuke, it looks like you want a variable width chamfer with the chamfer width dropping to 0 some distance further along the edge?
Unfortunately MOI does not have a variable width chamfer option. It does have a variable radius fillet however.
The way you could use it is to cut this edge using the Edit > Trim command with the "Add trim points" button so that it will be split like this:
Then select the edges and run Fillet, put in 0.5 for the main radius and then under "Fillet set" add in a new point set, set the "Linear Blend option", pick the point where you split the edge and enter in 0 for the radius there.
That will build a fillet like this, then you can delete the fillet surfaces and use Loft between 2 edges at a time to build the chamfers.
= Michael
Or another possibility is to do the chamfer along the entire area, then boolean union the end part so you have this:
Then if you copy this edge over:
You can then make a cylinder with Construct > Revolve:
Then boolean difference using the cylinder as the cutting object:
Michael.
I tried your first trick to get the right chamfer easily enough, but I can't get my head around what you did in your second example, Could you do a short video showing how things are orientated and how you placed the axis of rotation for the cylinder, please?
Martin.
Hi Martin, I selected the edge and then ran the Transform > Copy command.
For the base point I clicked on the chamfer surface that is near the edge, then used surface normal snap to some distance away, looks like this:
Thanks, Michael.
The video was most helpful. MoI's incredibly powerful snap & construction line combination is just great in all sorts of ways.
Martin.
Show messages: All
1-2
3-8
