Show messages: All
1
2-5
Hi neil,
> is there a script that can act as the eye button on the hidden layer ?
I'm not sure what you mean by "the hidden layer" - do you mean a style that is named "Hidden"?
yes the style called hidden
Hi neil, paste this in as the "command" part of a shortcut key. Then when you press that key all objects assigned to a style named "Hidden" will be hidden.
script: var objects = moi.geometryDatabase.getObjects();
var style = moi.geometryDatabase.findStyle( 'Hidden' );
if ( style )
for ( var i = 0; i < objects.length; ++i )
var obj = objects.item(i);
if ( obj.styleIndex == style.index )
obj.hidden = true;
var subobjs = obj.getSubObjects();
for ( var j = 0; j < subobjs.length; ++j )
var subobj = subobjs.item(j);
if ( subobj.styleIndex == style.index )
subobj.hidden = true;
thank you i wanted that one. legend
Show messages: All
1
2-5
