Full Version: alternate pan
27 Nov 2025   [#1]
I use blender and rhino frequently and would like to change the moi "pan" setting so that I can use Middle Mouse press + shift to pan instead of the current default which is to hold right click. Anyway to do this?
Best,
27 Nov 2025   [#2] In reply to [#1]
Hi AG101, the default for pan is already by holding down the middle mouse button, either with shift or just by itself with no modifier key.
If your 3D view is rotating with the middle button and panning with the right button you probably have the option turned on under Options > View > "Rotate/Pan/Zoom options" > "Rotate with middle button".
Turn that off to return back to the default behavior:
28 Nov 2025   [#3] In reply to [#2]
Hi Michael! Happy Thanksgiving.
Yes, that is my current setting for rotating the view. I'm asking if there is a way to "pan" by holding middle mouse button + shift. Ideal scenario is as follows:
Rotate view: Middle Mouse Button hold.
Pan View: Middle Mouse Button hold + Shift Key.
The above will mimic the same as Blender and Rhino 8!
Best,
28 Nov 2025   [#4] In reply to [#3]
Hi AG101,
> holding middle mouse button + shift. <...>
Yes, if you turn off "Rotate with middle button" as shown above then you should get pan by holding the middle mouse button, either with or without shift.
But then rotate view will be on Right Mouse Button.
There is not currently a way to have rotate on Middle Mouse Button and pan on Middle Mouse Button + shift but I will see about adding in an option for that.
30 Nov 2025   [#5] In reply to [#4]
Thanks Michael!
It would be one less level of friction using Moi if it was an option. It's especially helpful when many things are faster in moi to do than rhino and you can simply copy paste in between the softwares!
