Show messages: All
1-7
8-20
We want to eat that! :)
A while ago, I added the "SwapUV", "FlipU", "FlipV" and "Update History" options to the flow command's UI for the same reason. They were documented for the scripting but not used in the UI, I guess for ui simplicity.
I'll attach it here
ExtraFlowOptions.zip
Ho now that's super neat, I new the few hidden commands, but I didn't know some parameter where also hidden in the interface. Thanks a lot for sharing this !
Flow command was yet some powerful, now it's a monster of power! ;)
A nice way to model the part.
Another thumbs up for the extra functions in Flow.
Thanks to both of you.
Martin.
@ Mo
In what folder must be placed this extra Flow Options ? In commands ?
In fact Both Normal folder Moi /commands Roaming folder / Moi / Commands
I've replaced it with the original "Flow" command, but if you want to keep the original, you can rename it to something else (for example, "Flow2.htm" and "Flow2.js"), place it in the "moi appdata commands" folder, and assign a shortcut (for example, Shift+F=Flow2). This way you don't need to replace it with every new release.
Perfect!
https://moiscript.weebly.com/enrobage--flow.html
Super cool! Also thanks to MO for the updated Flow!
I'm seeing the Update History but not the Swap and Flip UV commands. Are these commands available somewhere? Thanks for sharing this Mo!
Hi danperk, those other options are only applicable for surface-to-surface Flow.
In your screenshot it looks like you're doing a curve-to-curve Flow instead.
Ah Thanks Michael, got side tracked by a candy cane! This is great, I've lost track how many times I've manually updated History for this kind of stuff.
"ExtraFlowOptions.zip" Thanks Mo for this! Flow is indispensable to us Jewelry Designers! :)
Show messages: All
1-7
8-20
