Full Version: Twisted Candy Cane
Show messages: All  1-10  11-20
28 Nov 2025   [#11]
Flow command was yet some powerful, now it's a monster of power! ;)
29 Nov 2025   [#12]
A nice way to model the part.
Another thumbs up for the extra functions in Flow.
Thanks to both of you.
Martin.
29 Nov 2025   [#13] In reply to [#9]
@ Mo
In what folder must be placed this extra Flow Options ? In commands ?
In fact Both Normal folder Moi /commands Roaming folder / Moi / Commands
29 Nov 2025   [#14] In reply to [#13]
I've replaced it with the original "Flow" command, but if you want to keep the original, you can rename it to something else (for example, "Flow2.htm" and "Flow2.js"), place it in the "moi appdata commands" folder, and assign a shortcut (for example, Shift+F=Flow2). This way you don't need to replace it with every new release.
29 Nov 2025   [#15] In reply to [#14]
Perfect!
https://moiscript.weebly.com/enrobage--flow.html
29 Nov 2025   [#16] In reply to [#7]
Super cool! Also thanks to MO for the updated Flow!
29 Nov 2025   [#17]
I'm seeing the Update History but not the Swap and Flip UV commands. Are these commands available somewhere? Thanks for sharing this Mo!
29 Nov 2025   [#18] In reply to [#17]
Hi danperk, those other options are only applicable for surface-to-surface Flow.
In your screenshot it looks like you're doing a curve-to-curve Flow instead.
29 Nov 2025   [#19]
Ah Thanks Michael, got side tracked by a candy cane! This is great, I've lost track how many times I've manually updated History for this kind of stuff.
14 Dec 2025   [#20]
"ExtraFlowOptions.zip" Thanks Mo for this! Flow is indispensable to us Jewelry Designers! :)
