Show messages: All
1-4
5-11
different behavior indeed:
sequoia 15.2 on mac mini M2
MoI v5 beta sept-17-2025 and feb-8-2025
Screen Recording 2025-11-15 at 22.24.59.mov
Hi wim,
That's odd - I tried on a couple different Macs and could not reproduce this behavior.
Do you possibly have multiple app windows open or have you installed any UI modifications?
No multiple app windows open, just one.
the one UI mod I did was the one you showed me a few years ago, to have all the interface windows open at the same time.
10063.3 In reply to 10063.1
Hi Wim,
re: > Can the Construct and the Transform menu's both be open at the same time, below each other?
Check out here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.3
That one separates all palettes out into individual ones. For just Construct / Transform use the attached one. These ones go in the Moi appdata "startup" folder.
Attachments: AttachmentSeparateSidePanePalettes2.js
Hi Wim,
It's probably from this script.
What happens if you disable the script, does your "Display hidden lines" checkbox work ok then?
You can disable the script by temporarily moving it out from the MoI appdata startup folder or renaming it to something other than having a .js file extension, like .jsx .
Yes Michael, that is the one, renaming did not help, removing the .js did.
wim
Thanks Wim, I'll see about fixing the script.
Hi Wim, please try this attached updated version of the script. Should work on v4 or v5.
If this fixes the broken "Display hidden lines" checkbox I'll also update the one on the original post.
Thanks, - Michael
SeparateSidePanePalettes.js
Show messages: All
1-4
5-11
