Full Version: Pick base point
Show messages: All  1-3  4-5
10 Nov   [#4] In reply to [#3]
Hi Marek,
> So, the Pick base point relates to spacing for each font?
The base point is where the bottom left point of the first character's cell will be placed.
> Well, then after getting several Text objects to have them aligned to say to the
> vertical red line which I put at the location of the guideline I have to move each
> object by hand, right?
No, the Transform > Align command can help with that.
Select each line of text and put it in a group (Scene Browser > Objects > "..." menu) so it will move as one unit.
Select them all:
Run Transform > Align and choose the "Left" option:
Pick the point on your line:
Does that give you the positioning you want?
11 Nov   [#5] In reply to [#4]
Sure it does, thank you.
Case closed.
Marek
