Show messages: All
1-3
4-12
Here a file (just a sphere). This file not getting the thumbnail.
In System Settings, the extension is enabled.
Reboot my mac, but no result.
Thanks.
test.3dm
Hi Finema, your file looks fine. It has a thumbnail stored in it and over here it is being displayed when the file is on the desktop:
Where is the .3dm file located on your system, is it on the desktop or somewhere else?
What is the full path to it?
Also if you have it on the desktop and select it and push space what does the preview window show for "open with", does it possibly have an old version listed in there? :
Man these cartoonishly large rounded corners all over in Tahoe are gross.
Thanks Michael
Everything is ok though…
See my screenshots
For info, in the .ini file, i have :
[3DM]
Version=
WriteThumbnailPreviewImage=y
ThumbnailSize=256
It's OK ?
Hi Finema,
> [3DM]
> Version=
> ThumbnailSize=256
>It's OK ?
Yes, those settings are ok. They are the default values.
Hi Finema, something else to check -
Click on your desktop and then on the Top menu click View > "Show view options"
Then make sure "show icon preview" is on.
And another thing you can try is from a Terminal prompt put in:
qlmanage -r cache
That will reset the thumbnail cache, it could help if it got damaged somehow.
Idem, no thumnail
Hi Finema, is the v5 beta also listed as being given permissions to access files?
I think that's under System Settings > Privacy & Security > "Files & Folders".
I checked the permissions in the system settings.
I also completely uninstalled Moi3D and reinstalled but still no preview.
Thank you.
Show messages: All
1-3
4-12
