Full Version: MOI3d CAM Alpha version
Show messages: All  1-6  7-11
15 Nov 2025   [#7] In reply to [#6]
I don't want to know which cam you are using actually, but can you spot a postprocessor in that list that fit your machine? I used this type of postprocessors because this is the biggest postprocessor library downloadable for free.
https://mecsoft.com/downloads/download-posts/
We can even make one from zero in case... I'm finishing the GUI to create post processors...
15 Nov 2025   [#8] In reply to [#7]
I have a Mach 3 controlled milling machine as well as a PlanetCNC lathe, both of these use a very similar g-code structure which is mostly interchangeable. The PlanetCNC controller can use g-code written for a LinuxCNC machine, so there is nothing unusual to allow for there.
Martin.
15 Nov 2025   [#9]
Wow amazing a long time RHINO CAM paired with a SHOPBOT PRS5 with 5th axis on windows 10 been solid for nearly 20 years,
Look forward to the release and costings?
13 Dec 2025   [#10]
https://web-production-1eaa4.up.railway.app/
I'm traveling in Asia, beta 1 is available... every key will last for 30 days, I will release a newer version before 30 days, I will create a discord channel for bugs and future developments. For sure there are some bugs, beginning of 2026 I will have time to fix them and to check everything in detail. Actually the files from some operations are already tested and used in production on 2 Doosan Puma 2100 and one Haas 3 axis.
13 Dec 2025   [#11] In reply to [#10]
I'd like to try this plugin, but I'm getting download warnings and the email confirmation went straight to spam, so I'll wait until something changes before dipping my toe into the water.
Thanks.
Martin.
