2-21
22-26
Hi Fabien,
> <...> I guess it would be nice if there was a Repeat option with that as well, so you
> could do multiple offsets interactively (with or without the step size provided).
There is a repeat option which is active for Offset:
Hi Fabien, here is an attempt at an offset with snap increment option.
OffsetSnap.zip
Does it normal that is always 2 offsets in the same time ?
Hi Pilou, yes currently it will display both the regular offset as well as the snapped one. When you finish picking the point only the snapped one will actually be generated.
I've set up something to be able to suppress showing the regular one in the next build.
Thanks Michael, and sorry for the late reply! I totally forgot about posting this here ...
It works exactly as I was hoping to! Looking forward to an update of Moi where the ghosting line can be suppressed.
- Fabien
2-21
22-26
