Full Version: looking for a script to create multiple offset lines
Show messages:  1-10  11-26
3 Nov   [#11]
But I have refound this! Maybe Michael don't remember of that! ;) 2012 ;)
https://moiscript.weebly.com/offsetmultistep.html
New French Version done! ;)
3 Nov   [#12]
Seems curves can be 3D but some fail to calculate!
Here a simple Helix
3 Nov   [#13] In reply to [#11]
Oops, I did forget that one, thanks Pilou!
English version here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4898.19
3 Nov   [#14] In reply to [#13]
There is a limitation written into this command. Can you see if it can be removed?
OffSetMultiStep
https://moi3d.com/forum/index.php?webtag=MOI&msg=4898.19
(Inches) With a distance of 1 anything over 12 steps starts to do a skip, space miscalc
If the distance is .25, then the steps have to be 48 or more
Anyway, let me know if this doesn't happen for you....
3 Nov   [#15] In reply to [#14]
Hi Burr,
Hmm, I'm not seeing it over here:
Can you please post an example file?
4 Nov   [#16] In reply to [#15]
Saw your post and created a new file and curve and it seemed to produce a proper result.
Changed the perameters like distance and a large count and then it stopped updating the count. If i put 50 it only created 11
closed and logged off and reopened moi and did it again and got the space...
Can you try a few different params with a larger count and verify it is only me?
Thank you..
offset odd.zip
4 Nov   [#17] In reply to [#16]
here is running it twice with 24 count
The first time it created the 1 block with only 7 objects. the last one spaced. Selected the spaced last object and got 3 sets of 7, spaced
4 Nov   [#18] In reply to [#17]
I am starting to think it is my test curves particular shape and not being able to offset that many times due to its back and forth wiggle...
Did some testing with a trimmed circle and offset to the outside and it would do 50 count fine
did a retest with a dramatically wavy curve and the count went down to only 2 objects created no matter how many was chosen.
I think it may be a "You cant offset that curve that many times without folding back on itself" issue...
4 Nov   [#19] In reply to [#18]
Hi Burr, does it generate the missing ones if you turn off the "Trim" checkbox?
It looks like offset is having difficulty detecting the self-intersecting spot on this particular shape. If this happens you can turn off Trim and then get some pieces to work with.
4 Nov   [#20] In reply to [#19]
That was it! And I didn't manage to use my dedouchary skills to equate the "trim" to getting the "compute anyway" result...
Just what I needed. Thanks for the help. Sorry to bother....
6 Nov   [#21]
Speaking off offset command variations, one thing I would be very interested in: interactive Offset Through Point with the option to put in a fixed increment/step size. For example an input value of 10 would snap the offset distance to 10, 20, 30 and so on. It's something I need very frequently, but right now I still need to put in the fixed distance myself for each one. I guess it would be nice if there was a Repeat option with that as well, so you could do multiple offsets interactively (with or without the step size provided).
6 Nov   [#22] In reply to [#21]
Hi Fabien,
> <...> I guess it would be nice if there was a Repeat option with that as well, so you
There is a repeat option which is active for Offset:
6 Nov   [#23] In reply to [#21]
Hi Fabien, here is an attempt at an offset with snap increment option.
OffsetSnap.zip
7 Nov   [#24] In reply to [#23]
Does it normal that is always 2 offsets in the same time ?
7 Nov   [#25] In reply to [#24]
Hi Pilou, yes currently it will display both the regular offset as well as the snapped one. When you finish picking the point only the snapped one will actually be generated.
I've set up something to be able to suppress showing the regular one in the next build.
18 Nov   [#26] In reply to [#23]
Thanks Michael, and sorry for the late reply! I totally forgot about posting this here ...
It works exactly as I was hoping to! Looking forward to an update of Moi where the ghosting line can be suppressed.
- Fabien
