Show messages: All
1-2
3-6
...I have a profile that I created in a standard 3D space. I need to apply it to several different defined 3D spaces. Redrawing it each time is time-consuming. Therefore, I want to transpose it into the different 3D spaces. I've now chosen a very simple circle as a dummy profile to be transposed.
cLevel transponding.3dm
Hi Mala, I'm not quite understanding the 3 lines in your model, are those meant to be the x,y,z axis lines for a coordinate system on the circle?
The part that is confusing is that usually something like that should have each axis at a 90 degree angle to the other axes. But yours is not set up like that.
There is a command Transform > Orient that can move and rotate objects from one coordinate system to another.
Here is an example using Transform > Orient on your circle to reposition it:
That´s what I´m looking for. THANKS A LOT!
Hi Mala, you're welcome.
Also if you're getting stuck with how to use the Orient command there is some information on how it works here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#orient
https://moi3d.com/forum/index.php?webtag=MOI&msg=3424.13
Show messages: All
1-2
3-6
