Full Version: Array - linear AND rotational?
Show messages: All  1-3  4-14
21 Oct   [#4]
It's not that important anymore. I render it in C4D, and there I can work with MoGraph, both linearly and rotationally.
Thx.
21 Oct   [#5] In reply to [#3]
Hi Mala,
> The movement is x=3cm y=3cm and the rotation is 5° at a specific point.
You can use the Transform > Copy command to make a copy at a specific distance and rotation at a specific point can be done with the Transform > Rotate command.
To make a copy at a distance of 3cm in x and 3cm in y, select the object and then run the Transform > Copy command.
The prompt will say "Pick base point", type 0 and push Enter to use 0,0,0 as the base point.
The prompt will now say "Pick target point", type 3,3 and push Enter and a copy will be created.
Then right click in a viewport or push "Done" to exit the command.
To rotate around a specific point, select the object and then run the Transform > Rotate command.
The prompt will say "Pick center of rotation", pick your specific point.
At the next prompt click the "Make copies" checkbox in the command options and then type your rotation angle.
22 Oct   [#6] In reply to [#5]
I made it in Cinema 4d. But I put it in my MOI-Wiki.
Thx...
22 Oct   [#7] In reply to [#6]
Can we see it ?
23 Oct   [#8]
A bit late but can be done with nodeditor.
Barry
24 Oct   [#9]
Excellent!
28 Oct   [#10] In reply to [#7]
At just this moment I saw your question to see the stapled stools, Pilou. I cannot show them here. But it is exactly what barry shows.
28 Oct   [#11] In reply to [#8]
What is the "new nodeeditor" Barry?
28 Oct   [#12] In reply to [#11]
Hi Mala, some information here on the node editor:
https://moi3d.com/wiki/Nodeeditor
28 Oct   [#13]
And ask the ".nod" file to Barry because use the node editor ask some training before! ;)
https://moiscript.weebly.com/biblio-elephant.html (Scroll some Infos about Node Editor (English / French)
28 Oct   [#14] In reply to [#11]
Hi Mala,
the new nodeditor plus is here.https://moi3d.com/forum/messages.php?webtag=MOI&msg=11614.1
But you can get the result you where looking for with the original nodeditor.
Barry
