Full Version: Helix rounded on average possible
16 Oct   [#1]
Hello, is it possible to make a helix with MOI that is rounded on average?
Helix Rounded.3dm
16 Oct   [#2]
Here i take a diagonal of a rectangle
Then Flow it on any symmetric bowl ( because curriously project a curve don't works)
I had one turn!
So stack the bowls !
That must make the trick! ;)
16 Oct   [#3] In reply to [#1]
Select curve and use the twist tool.
Barry
16 Oct   [#4] In reply to [#2]
Thx. But I cannot follow your workflow.
16 Oct   [#5] In reply to [#1]
see photo.
Barry
16 Oct   [#6]
About my not speed method :)
Sorry in fact you don't stack the bowls but you trim it horizontally!
Then Flow the diagonal of the rectangle on each slice bowl part :)
Not the helix following!
16 Oct   [#7] In reply to [#1]
Hi Mala, if you're still stuck you can also reference this previous discussion thread here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11777.1
17 Oct   [#8] In reply to [#7]
Almost perfect for my effort, Michael. Thank you very much!
Also to all your other ideas !
Best, Mala
