Full Version: Sweep fails - why?
Show messages: All  1-15  16-20
16 Oct   [#16] In reply to [#7]
Hi Mala, also the same steps will also work for your sweep fail 3.3dm file above.
result attached.
sweep fail 3 fixed.3dm
16 Oct   [#17]
Maybe more simple...
And advantage you can have start and target section different... here 2 circles but...
Make a boolean Diff between cylinder and plane
16 Oct   [#18]
Ok. I learned very much (again). Thanks to you Michael and also for the smart way, Pilou!!! Now I can progress...fine.
16 Oct   [#19] In reply to [#18]
attached photo shows a method to get the twist direction you require. By creating a surface with desired twist.
Then array required section along curve aligned to surface and finally loft sections.
Barry
16 Oct   [#20] In reply to [#19]
Thank you!
