Full Version: V5 beta Sep-17-2025 available now
Show messages:  1-17  18-37  38-57  58-77  78-97  98-104
3 Jan   [#78]
Michael, so glad to see you are still at it.
It's been soooo long...the website where I first heard about moi3d (cgtalk) doesn't even exist anymore. :)
Hope you are doing well, and wish all the community here prosperity in the new year.
9 Jan   [#79]
If I open a .stp or .igs (may be others, those are just the ones I have), there is now way to know what file is open in the MoI widow. Is there a way to add the file name somewhere?
.3dm shows the file name in the top window bar.
9 Jan   [#80] In reply to [#79]
From an iGes you have Nature and internal object name from the start Program when you click on it!
(but sure not the File name itself! :)
9 Jan   [#81]
Re: Is there a way to add the file name somewhere?
Set SetNameWhenOpeningAllFileTypes=y in moi.ini under [Settings] at the top of the file. Access moi.ini by going to Options > General > Edit .ini file
- Peer
9 Jan   [#82] In reply to [#81]
Yep works fine pom.IGS becomes directly pom.3dm*
Details gives the same than above...
9 Jan   [#83] In reply to [#81]
Perfect. Thanks Peer!
17 Jan   [#84]
WELLl DONE Michael for this version V5 and new enhancements of Moi3D software.I finally put it in good use even I use V3 version.It shows me if object is solid or joined surfaces,which is very important for 3d printing.I always mention people that Moi3d is very precise CAD software and if they wish to customize my 3d models,they can download trial version.
Keep up with great work Michael :)
If you like please check it out my 3dprintable aircrafts and spaceships on link below.Give me some likes if You wish :)
https://www.crealitycloud.com/user/5781596056
17 Jan   [#85]
Very cool models !
17 Jan   [#86] In reply to [#70]
I am right clicking and dragging. I have been using it this way for years. Sometimes it will start to orbit and then stop and and open file dialog even though I am still dragging. But you are correct that its not just open, its whatever the last command I used. So if I draw a circle, then go and right click to orbit, it will sometimes go straight to drawing a circle again, sometimes it will orbit and sometimes it will orbit and then switch to drawing a circle.
>Len
18 Jan   [#87] In reply to [#86]
Hi Len, do you possibly have another mouse you could try? If the switch on your mouse button is getting worn out and giving spurious release events that could look like that.
17 Mar   [#88] In reply to [#1]
This new version looks great for guitar builders!
23 Mar   [#89]
Just dropping by to say what amazing software MOI is and how user friendly it is.
This new V5 is something else.
Thanks Michael.
23 Mar   [#90]
Hi Michael, hope you’re doing well!
After quite a long break from actively participating in the forum, even though I’ve still been dropping by as a reader from time to time, I’ve decided to get back into using Moi again. I’ve always considered it one of the best 3D modeling programs ever written.
For now, I have a few questions:
1. Do you have an estimated release date for the official V5, and what will the upgrade price be from V4?
2. Where can I find complete and up-to-date API documentation for Moi? I’m especially interested in the JavaScript interface, as I’d like to experiment with developing some new scripts.
3. What are the main differences in Moi when using the “ACIS” libraries versus “Solid++” for creating fillets and chamfers?
Thanks in advance, and all the best!
23 Mar   [#91] In reply to [#90]
Hi Marco, welcome back!
I don't have a specific date set yet but hopefully pretty soon.
Upgrade price is expected to be the same as previous version upgrades, which is $100.
There is not any official documentation for MOI scripting available, but there is some collected by users here:
https://moi3d.com/wiki/Scripting
Mostly that the ACIS libraries are far more robust and handle many cases that fail with Solids++.
25 Mar   [#92]
Approaching this question from a different angle: the current build expires in 4 weeks. Do you estimate that were would be a period where we have to revert back to the v4 while the v5 release is shaping up after expiration, or would there be a new build (even just an extension of the expiration date) to bridge the gap?
25 Mar   [#93] In reply to [#92]
Hi summarity, I will make a new v5 beta build with an extended expiration soon. I'll make sure that there is a v5 beta that overlaps the v5 release.
26 Mar   [#94]
Thanks Micheal!
A separate question:
I'm working on a few plugins targeted at v5. Are there plans to update the embedded JS/web engine? AFAICT MoI 5 is using QtWebKit, which works, but has been deprecated for about 7 years and replaced by QtWebEngine. There was a fork for a while at qtwebkit/qtwebkit, which was abandoned 3 years ago, then MoveableInk picked up a new fork at https://github.com/movableink/webkit - no idea if this would be a viable upgrade path compared to moving to QtWebEngine.
This leads to some friction trying to use fairly standard development tools, e.g. TypeScript targeting ES6, even targeting very early 2016-ish syntax or styles using CSS grids or flexbox features which were standardized shortly after the cutoff when QtWebKit development ceased.
This is on macOS, so I don't know if this is different for the Windows builds.
26 Mar   [#95] In reply to [#91]
Ok. Thanks Michael.
You wrote: "There is not any official documentation for MOI scripting available, but there is some collected by users here: https://moi3d.com/wiki/Scripting"
Thanks for your reply, Michael, I appreciate it :)
Alright, noted :)
I was hoping though that, as the developer of Moi, and therefore the person who knows the API specifications and the JavaScript interface better than anyone else, you might be able to provide some official documentation for these APIs.
I’m asking because, as a software developer myself, I think you can understand that this is a pretty reasonable request. When it comes to API specifications, there’s nothing worse than not knowing where to find them, or having to rely on unofficial documentation put together by various users, without any intention of disrespecting those who contributed to the scripting guide you mentioned.
Would it be possible for you to put together a complete and official documentation of Moi’s APIs and its JavaScript interface? I believe it could really be in the best interest of Moi and its community :)
Let me know, thanks!
26 Mar   [#96] In reply to [#95]
Hi Marco,
It would be if I had been marketing the script API as a core feature of the program.
But I have not done that.
No, it is not possible to generate complete and official documentation without expending a large amount of time and effort.
26 Mar   [#97] In reply to [#94]
Hi summarity,
Not currently. That would probably also need to update Qt as well. That's a lot of work invovled and at the end of it there would be nothing gained by the average non-programmer MOI user. So it's difficult to justify scheduling that.
What are the flexbox features that you're missing?
= Michael
