Full Version: V5 beta Sep-17-2025 available now
Show messages:  1-8  9-28  29-48  49-68  69-88  89-104
20 Nov 2025   [#69] In reply to [#68]
Don't worry. These things happen.
Happened to me the first few times I used Linux, actually.
12 Dec 2025   [#70]
With this new beta, when I right click to orbit (about half the time) it opens up a file open dialog when I release the right mouse button. Any ideas?
>Len
12 Dec 2025   [#71] In reply to [#70]
Hi Len,
Are you doing a right click to orbit but then releasing the button without any movement?
When you right click in a viewport like that it's a shortcut for pushing the "Done" button or if you are not currently in a command it will repeat the last used command. If you have just opened a file then the last used command is Open.
If you don't want the Open command to repeat like that there is a setting in moi.ini you can use. Go to Options > General > "Edit .ini file" button and in the [Commands] section there is a setting NonRepeatingCommands, add open to it so it looks like this:
NonRepeatingCommands=delete undo redo open
14 Dec 2025   [#72]
Oh yeah, the right-click repeat trick. My personal favorite.
16 Dec 2025   [#73]
Hi Michael, what you think to add ability make differen color to construction lines? For concepting, make them separate by angle visially
16 Dec 2025   [#74] In reply to [#73]
Hi blackboard,
Do you mean by assigning a style? Or by some automatic process?
16 Dec 2025   [#75] In reply to [#74]
Thanks for fast answer Michael.
For my problem - to find visualy similar angles of surfaces i think will be better to have automatic ability made it different color when this lines on custom angle not 0\90\180\270\360.
I propose when in scene you have two or more same angle constraints - bind them a one special color. If someone add them on one angle and with custom angle i think this have sense to visualy made it clearer(For some reason user made it a couple versions and i think it can improve user expirience). When this construction lines more it can be a mess.
I think also add checker box to change it from gray to multicolor made sense too, or make also not vivid colors
16 Dec 2025   [#76] In reply to [#75]
Hi blackboard, it's an interesting idea but that's a lot of things to try and control. It seems like it would be a pretty complex UI.
20 Dec 2025   [#77]
Love the update! I've had a blast modelling some simple lens holders today and couldn't resist playing with the new features.
The move face feature covers one of my main pain points when switching to MoI from Rhino (would love to see ability to move edges). Heck, at this point the only annoying thing that immediately comes to my mind when I think of it, is selection priority when making fillets / chamfers. If I extrude a profile and then want add some fillets to the edges of a resulting solid the original curve overlaps with the edges - and comes in the way. Fillet command picks this curve instead of edge. Would love to have some sort of selection priority with this command - pick edges first, if none pick curve.
In Rhino this is not that annoying as Rhino asks which object you wish to select when there are overlaps (so in this case - a menu would appear with option to pick edge or curve). It's not fantastic either, but definitely less annoying.
For the time being I've mapped a key to hide curves... but that's not really great solution.
But that sounds a bit like a rant - which it really shouldn't. The update is fantastic. And a side note - I'm surprised how well in works on my Linux box with tiling window manager (Hyprland) via Wine. One of the reasons that instead of launching a VM with pcie passthrough (and LookingGlass) or grabbing my Rhino laptop I simply did the modelling in MoI (and I'm glad I did :) ).
3 Jan   [#78]
Michael, so glad to see you are still at it.
It's been soooo long...the website where I first heard about moi3d (cgtalk) doesn't even exist anymore. :)
Hope you are doing well, and wish all the community here prosperity in the new year.
9 Jan   [#79]
If I open a .stp or .igs (may be others, those are just the ones I have), there is now way to know what file is open in the MoI widow. Is there a way to add the file name somewhere?
.3dm shows the file name in the top window bar.
9 Jan   [#80] In reply to [#79]
From an iGes you have Nature and internal object name from the start Program when you click on it!
(but sure not the File name itself! :)
9 Jan   [#81]
Re: Is there a way to add the file name somewhere?
Set SetNameWhenOpeningAllFileTypes=y in moi.ini under [Settings] at the top of the file. Access moi.ini by going to Options > General > Edit .ini file
- Peer
9 Jan   [#82] In reply to [#81]
Yep works fine pom.IGS becomes directly pom.3dm*
Details gives the same than above...
9 Jan   [#83] In reply to [#81]
Perfect. Thanks Peer!
17 Jan   [#84]
WELLl DONE Michael for this version V5 and new enhancements of Moi3D software.I finally put it in good use even I use V3 version.It shows me if object is solid or joined surfaces,which is very important for 3d printing.I always mention people that Moi3d is very precise CAD software and if they wish to customize my 3d models,they can download trial version.
Keep up with great work Michael :)
If you like please check it out my 3dprintable aircrafts and spaceships on link below.Give me some likes if You wish :)
https://www.crealitycloud.com/user/5781596056
17 Jan   [#85]
Very cool models !
17 Jan   [#86] In reply to [#70]
I am right clicking and dragging. I have been using it this way for years. Sometimes it will start to orbit and then stop and and open file dialog even though I am still dragging. But you are correct that its not just open, its whatever the last command I used. So if I draw a circle, then go and right click to orbit, it will sometimes go straight to drawing a circle again, sometimes it will orbit and sometimes it will orbit and then switch to drawing a circle.
>Len
18 Jan   [#87] In reply to [#86]
Hi Len, do you possibly have another mouse you could try? If the switch on your mouse button is getting worn out and giving spurious release events that could look like that.
17 Mar   [#88] In reply to [#1]
This new version looks great for guitar builders!
