Full Version: V5 beta Sep-17-2025 available now
Show messages:  1-10  11-30  31-50  51-70  71-90  91-104
24 Sep 2025   [#31] In reply to [#29]
Hi Pilou, for fewer steps you could do -
"Details..." button, then on the object properties dialog, click "Faces", then Ctrl+click on "Planar" to deselect those.
Or on Scene Browser, Types section, click on the selection dot area for "Faces", then click on selection dot on Faces > Planar to deselect planar faces.
24 Sep 2025   [#32] In reply to [#30]
Frenchy.
If you delete just the rounded apex faces you get 'straight corners' on the fillets. ;-)
Martin.
24 Sep 2025   [#33] In reply to [#31]
Ah excellent! Another hidden fonctions!
24 Sep 2025   [#34] In reply to [#32]
@blowlamp
Yep but you don't obtain the same result!
All depend of what do you want! ;)
But maybe Apex is another thing... ? What is exactly ?
And what is your selection ?
24 Sep 2025   [#35] In reply to [#34]
Frenchy.
You're showing what I meant in your GIF.
The fact that it's now possible to have straight corners and rounded corners in any combination is a plus as far as I'm concerned. ;-)
The same trick also works with Chamfer. ;-)
Martin.
24 Sep 2025   [#36] In reply to [#1]
I've been waiting for this since v3!
Thank you!
25 Sep 2025   [#37]
looks like u are hitting the same overhead as
https://www.youtube.com/watch?v=WvwiH1DOK1M
great improvements, have been asked for a long time !
25 Sep 2025   [#38]
Not a question about the Sep-!7-2025 beta in particular.
I know it's possible to enter fractions such as 17/64" without having to convert to decimal, but is there a formatting rule where I can enter a measurement of something like 4 9/16" directly?
I occasionally get these dimensions in drawings I receive and don't enjoy converting them. ;-)
On my mobile phone calculator, entering 4+9/16 seems to give the right answer.
Martin.
25 Sep 2025   [#39] In reply to [#38]
Hi Martin,
Yes, you need to have a unit system set other than "No unit system", and you need a foot (') or inches(") mark in your input.
Then you can use either a space or a hyphen to separate whole inches from the fractional part, like:
4 9/16"
or
4-9/16"
25 Sep 2025   [#40]
Just saw this. Currently installing as I speak, and I am super excited to try this out.
25 Sep 2025   [#41] In reply to [#39]
Thank you Michael.
It's now working for me if I use a hyphen, but not with a space and of course I was previously using a space.
My unit system is set to millimetres.
Martin.
25 Sep 2025   [#42] In reply to [#20]
Amazing and everyday useful ACIS funkcionality, excellent job, Michael!
Thank you.
Mik
25 Sep 2025   [#43] In reply to [#41]
Hi Martin,
Which edit field are you typing in ?
25 Sep 2025   [#44] In reply to [#43]
Michael.
I click to start the line and immediately begin typing on the numeric keypad and the numbers are displayed in the X,Y,Z box without me clicking on it.
If I click to start the line and then type: 4-7/8" the line is correct.
If I click to start the line and then type: 4 7/8" the line terminates somewhere near the Origin, in fact all lines show similar behaviour whe using the 'space' character.
Martin.
25 Sep 2025   [#45] In reply to [#44]
Hi Martin,
> all lines show similar behaviour when using the 'space' character.
In that particular field it's also looking for x y values and it's deciding that 4 7/8" is a 2D point location with
x = 4
y = 7/8 inches = 22.225mm.
But I can probably tune that if you have the inches mark (") on just one piece then treat the whole thing it as one feet & inches value instead.
25 Sep 2025   [#46] In reply to [#45]
Hi Michael.
That would be good if you're happy to do it.
Just to let you know that the new features are an absolute boon when it comes to editing a model. Just being able to delete features to allow further editing is fantastic!
Martin.
26 Sep 2025   [#47]
The moi3d function is already well-developed and easy to operate. As a purchasing user, could you consider designing a new UI to enhance the competitiveness of this product,https://www.behance.net/gallery/175633629/Moi3D
26 Sep 2025   [#48] In reply to [#47]
Hi feirui445,
There is a new "Dark Mode" UI available in version 5, you can turn it on under Options > General > "UI Theme: Dark".
See here for some discussion of some of the problems with that particular graphic design example that you link to:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11158.2
Just purely cosmetic graphic design "looking cool" is a very low priority for MoI compared to actual workflow UX design.
I'm definitely not interested in losing actual usability just for a cool look.
26 Sep 2025   [#49]
Interesting.
26 Sep 2025   [#50] In reply to [#47]
If MoI had looked like that when I wanted to buy a CAD, I'd have carried on looking.
Martin.
