Full Version: Best way to make a shell
Show messages:  1-15  16-35  36-41
21 Sep   [#36]
New Sep-17-2025 v5 beta version now available at
https://moi3d.com/beta.htm
Will be working on full release notes a bit later, there are more functions integrated from the ACIS geometry kernel.
Selected faces can now be manipulated with the Transform > Move, Transform > Rotate and Transform > Rotate Axis
commands. This uses the ACIS direct model editing component to extend and intersect surrounding faces to
accommodate the change.
Enables dynamic editing of solids like this:
New RemoveAndFill command - use Shift+Delete keyboard shortcut or Shift+click or right click on Delete button to invoke ACIS Remove component that deletes faces and then heals the resulting openings by extending and intersecting surrounding faces:
ACIS Shell function is now used by the MoI Construct > Offset > Shell command.
Also lots of fixes for ACIS filleting.
21 Sep   [#37] In reply to [#36]
French version! ;)
https://moiscript.weebly.com/
21 Sep   [#38] In reply to [#36]
Smooth!
22 Sep   [#39] In reply to [#36]
Very cool, thanks Michael. Going to install it right away.
23 Sep   [#40] In reply to [#27]
Hi Michael.
Thanks for the advice on using the Offset tool - it worked beautifully.
With the new Delete Face tool I'm able to discard any superfluous parts to get the cores as I want them.
All the new features are working great with only the occasional 'phantom surface' when I Shell fairly complex parts. I could send a file if you need one.
As I only have a slow laptop, I can get a significant lag when using the new Move Face tool as MoI updates whilst trying to keep up with mouse movement, so I wondered if the live update could somehow be suspended until Moi had locked onto an intersection point or maybe turned off if necessary?
Thanks again.
Martin.
23 Sep   [#41] In reply to [#40]
Hi Martin,
Yes it would be helpful to get the file, especially before doing the shell so I can repeat the steps.
Please e-mail it to me at moi@moi3d.com .
I'll put in an option for this.
Thanks, - Michael
