Show messages: All
1
2-5
Hi Berk, MoI version 5 has a theme function that can be used to customize colors of UI elements.
You can get the v5 beta at
https://moi3d.com/beta.htm .
The theme function is under Options > General > "UI Theme".
You can switch there to the dark theme and you can push "Manage themes" to set up your own customized theme.
Got it, thank you!
Hi Michael
Is it possible to make a copy og the standard dart theme so i van make a few adjustments
Hi Hep,
Yup, when you create a new theme there is an option for which standard theme it should be based on.
Go to Options > "Manage themes":
Then "Create new theme":
Then it's the "Copy from:" option here:
Show messages: All
1
2-5
