Full Version: UI Customization for newbies
1 Jul   [#1]
Hey there,
I've been transitioning from Fusion 360 for a little while now and loving the fast workflow between Adobe Illustrator and MOI.
While diving a little deeper, I've found various super cool scripts and a layout set in here and YouTube. What I've been wondering is how to customize the UI layout and color like examples below. Would appreciate any help.
Thanks!
- Berk
Screenshot 2025-07-02 at 02.45.21.png  Screenshot 2025-07-02 at 02.55.32.png  Screenshot 2025-07-02 at 02.56.44.png
1 Jul   [#2] In reply to [#1]
Hi Berk, MoI version 5 has a theme function that can be used to customize colors of UI elements.
You can get the v5 beta at https://moi3d.com/beta.htm .
The theme function is under Options > General > "UI Theme".
You can switch there to the dark theme and you can push "Manage themes" to set up your own customized theme.
4 Jul   [#3] In reply to [#2]
Got it, thank you!
27 Sep   [#4]
Hi Michael
Is it possible to make a copy og the standard dart theme so i van make a few adjustments
27 Sep   [#5] In reply to [#4]
Hi Hep,
Yup, when you create a new theme there is an option for which standard theme it should be based on.
Go to Options > "Manage themes":
Then "Create new theme":
Then it's the "Copy from:" option here:
