Full Version: Automatic center when selecting an item?
Show messages: All  1-12  13-14
25 Apr   [#13] In reply to [#12]
Hi Matadem, thanks for posting the file.
Inside the Loft command, you can set the option for "Profiles: Exact" :
With that set, you should then get center snaps on the top and bottom faces, can you confirm?
26 Apr   [#14]
Yes that did it!
When you draw for long hours every little bit that can save time helps.
Thank you!
