Show messages: All
1-11
12-14
All are lofted.
the first is lofted with the bottom extruded, curves deleted, boolean union
the second is lofted curves deleted
the 3d is lofted and left as is and here you can pickup the center.
Tnx.
loftgear2.3dm
Hi Matadem, thanks for posting the file.
Inside the Loft command, you can set the option for "Profiles: Exact" :
With that set, you should then get center snaps on the top and bottom faces, can you confirm?
Yes that did it!
When you draw for long hours every little bit that can save time helps.
Thank you!
Show messages: All
1-11
12-14
