Full Version: Automatic center when selecting an item?
Show messages: All  1-10  11-14
25 Apr   [#11] In reply to [#10]
Hi Matadem,
> I have loft it and I removed the curves, boolean union....once the curves removed
> you can no longer select the center on top.
I'm not seeing the curves to loft in that .3dm file.
Can you please post the .3dm file that matches what you write about so I can repeat the steps?
Thanks, - Michael
25 Apr   [#12]
All are lofted.
the first is lofted with the bottom extruded, curves deleted, boolean union
the second is lofted curves deleted
the 3d is lofted and left as is and here you can pickup the center.
Tnx.
loftgear2.3dm
25 Apr   [#13] In reply to [#12]
Hi Matadem, thanks for posting the file.
Inside the Loft command, you can set the option for "Profiles: Exact" :
With that set, you should then get center snaps on the top and bottom faces, can you confirm?
26 Apr   [#14]
Yes that did it!
When you draw for long hours every little bit that can save time helps.
Thank you!
