Full Version: Not solid after boolean and clipboard question
Show messages: All  1  2-3
6 Apr   [#2]
Your fillets are over lapping. the model can't figure out which way is facing out.
Val
6 Apr   [#3] In reply to [#1]
Hi Matadem, yes like Val says above your fillet radius is too large and there is an area with a messed up trim boundary here:
> also when you copy an item does it go to the windows clipboard?
With the Edit > Copy command or Ctrl+C / Cmd+C, yes.
> I tried it but my clipboard is empty and
What are you using to look at the clipboard?
> if it works can it be setup to be as an obj file onto the clipboard?
The .obj spec does not have anything in it about the clipboard, so it's not possible.
