Full Version: Feature you coded for me doesn't work in V5
Show messages: All  1-4  5-8
25 Mar 2025   [#5] In reply to [#4]
Yes, I was selecting items within a group.
I will try your suggestions when I have a free moment.
Frederick
25 Mar 2025   [#6] In reply to [#4]
Your first idea seems to have solved the problem.
While we are looking at this code one question:
When invoking the command the first thing it does is put up a dialog requiring me to pick STL or 3DM.
I always pick STL.
Is there any way to bypass the asking and simply default to STL?
Thanks.
Frederick
25 Mar 2025   [#7] In reply to [#6]
Hi Frederick,
Yup, in ExportParts.js find line 22 that has this:
if ( WaitForDialogDone() ) DoExportParts(objectpicker.objects);
and change it to this:
/*if ( WaitForDialogDone() )*/ DoExportParts(objectpicker.objects);
That will bypass the asking stage and go immediately to the exporting.
Then to make it use .stl format find line 29 which has this:
var d = moi.ui.commandUI['extension'].value;
var d = '.stl'; /*moi.ui.commandUI['extension'].value;*/
That will make it always use STL format instead of getting it from the UI control.
25 Mar 2025   [#8] In reply to [#7]
I can handle that.
I even understand most of it.
Frederick
