Full Version: Import cloud points options?
Show messages: All  1  2-12
24 Mar 2025   [#2] In reply to [#1]
I’ve done it before with Notepads “find and replace”
I think i resorted to excel once also. More powerful options for tuples..
I didn't ask Michael about it though. Maybe he has a more eloquent way…
24 Mar 2025   [#3]
A cool free prog about cloud points! ;)
http://cloudcompare.org
24 Mar 2025   [#4] In reply to [#1]
Hi Matadem, here's a modified version of the ImportPointFile script which should handle your CAM program's point output.
This one should skip the G1 at the start of a line and will remove any X or Y label on the coordinates.
Instructions for installing a plugin here.
Hope this helps,
ImportPointFileMatadem.zip
24 Mar 2025   [#5]
Michael can it do z as well?
I tried the script and it works fast and efficient as always.
Tnx!
24 Mar 2025   [#6] In reply to [#5]
Hi Matadem,
I didn't see any z coordinates in your example, but it if it has a 'Z' label on it like it does for X and Y you can update the script to handle that.
Open the ImportPointFilematadem.js file in a text editor and on line 112 which currently has this:
			if ( val[0].toUpperCase() == 'X' || val[0].toUpperCase() == 'Y' )
Change it to this instead:
			if ( val[0].toUpperCase() == 'X' || val[0].toUpperCase() == 'Y' || val[0].toUpperCase() == 'Z' )
24 Mar 2025   [#7]
Works good!
Tnx!
29 Mar 2025   [#8] In reply to [#7]
Sorry if I am interrupting this thread, but can this script import point clouds created via photogrammeyry. I use Zephyr3D for my photscans.
Ken
29 Mar 2025   [#9] In reply to [#8]
Hi Ken,
The script can import points that are listed in .csv file.
It should be a text file with the x,y,z coordinates for one point on each line of the file.
22 Apr 2025   [#10]
Good day.
One more issue.
The script is working awesome.
When I probe walls and unusual shapes it works...
but today I found out that if I probe circles it will run another type report. and then the script will not work.
the new report looks like this
Version: 0.0.0.1 1
New Probe Cycle
Enter Description Here
2025-Mar-23 00:13:52
Center of Bore
-5.557700
0.243719
3.664379
New Probe Cycle
2025-Mar-23 10:10:48
Center of Bore
-2.541250
-0.250592
1.620377
first is x the second y and the 3rd is radius.
Is there a way for the script to read the points and create the circles based on the radius info????
Tnx!
22 Apr 2025   [#11] In reply to [#10]
Hi Matadem, here is a circle reading script.
ImportCircleFileMatadem.js
22 Apr 2025   [#12]
Thank you very much.
These will save me allot of time!!!!
