Show messages: All
1
2-3
Hi Frederick,
> Any idea what I might have done?
Hmmm, well Ctrl+drag on an object will drag away a copy of an object is that possible?
> Why does this happen?
The yellow bits are a "preselection halo" that shows when curves are going to be selected if you clicked.
It looks like this in the more regular situation when you move your mouse over a curve:
It does look a little weird when the curve is in a group and behind solids. I'm not sure what to do about that, I'll have to experiment some.
Maybe the halo part should not draw over top of everything when it's in a group.
Thanks, - Michael
Now that I know what the cause of the "yellow bits" is I went back to the original step file and imported it again into MoI.
Those bits appear to be (guessing here) left over bits of "construction lines".
They clearly not part of the the BLTouch unit.
So I simply deleted them and now have a clean model to import in the future.
Thanks to you.
Still the issue of things like that showing up when undesirable remains - something for you to ponder.
Thanks.
Frederick
Show messages: All
1
2-3
