Full Version: huge difference between file formats stp and MOI's 3dm
27 Feb 2025   [#1]
Hello Michael and forum community,
I work with a lot of STP files, which I then clean up by deleting invisible objects and inner parts before saving them in MOI's native format.
Usually, the cleaned version saved as a 3DM file in MOI is about twice the size of the original STP.
However, some files turn out to be extraordinarily larger.
For example:
original file with a lot of inner parts and surfaces: 72mb in stp file format
moi clean version is 875mb in 3dm file format.
another example:
88mb in stp file format
527mb in 3dm file format
From my side, I only noticed that this issue occurs with files containing highly detailed geometry, like this part. Please take a look at the screenshot.
My question is very simple: why does this happen, and what can be done about it?
Thanks in advance
27 Feb 2025   [#2] In reply to [#1]
Hi brr, it's kind of hard to diagnose without being able to analyze the actual files, but
it's likely that the ones with the biggest difference are using instancing in the STEP file.
Since MOI does not yet have an instancing mechanism, when it reads in the STEP file
any instances will become a full separate object.
There isn't really anything to do about it currently.
6 Mar 2025   [#3] In reply to [#2]
Hello Michael,
Thank you for the information. Are there any plans to implement instancing in MOI v5?
Thanks in advance.
6 Mar 2025   [#4] In reply to [#3]
Hi brr, sorry no not likely in the v5 timeframe.
6 Mar 2025   [#5]
What is instancing ?
6 Mar 2025   [#6] In reply to [#5]
Hi Pilou, instancing is a method of managing a large number of copies of the same object.
6 Mar 2025   [#7] In reply to [#6]
OK before an hypothetic instancing ...we can't simulate that ?
with copy to point by you
& VClone by MaxSMirnov
Vclone replaces the vector with the object with size and orientation!
6 Mar 2025   [#8] In reply to [#7]
Hi Pilou, yes you can simulate some aspects but the main thing that the simulation is missing is efficency in data size.
With instancing each "instance" is handled by maintaining the insertion point and not making a full separate object copy.
6 Mar 2025   [#9] In reply to [#8]
ok!
