Full Version: Solid imports with errors
Show messages: All  1-8  9-14
16 Feb   [#9] In reply to [#6]
Hi Bob, could you post an SAT out from Alibre? Maybe that will be a better way.
16 Feb   [#10]
The step file is a mess in Rhino8 as well.
16 Feb   [#11]
Here's a SAT zip. The Gods are against me, even the Zip files not wanting to convert properly!
Nacelle in SAT Zip.zip
16 Feb   [#12] In reply to [#11]
Hi Bob, are there any options for Alibre's SAT export? If so can you show me the options dialog for it?
Is the piece with fins one solid in Alibre or a bunch of separate surfaces? It seems to be surfaces in the SAT file.
16 Feb   [#13] In reply to [#11]
Is that SAT file from Alibre or MoI?
Its made with the harmony ware translator. I wasn't aware that Alibre used that library...
Since Alibre is Acis based, the best export out should be the SAT format, from Alibre.....
17 Feb   [#14] In reply to [#11]
Hi Bob, here's a version with things tuned up to be solids:
https://moi3d.com/temp/Bob9595593/Nacelle%20For%20Testing2_3dm.zip
There were several areas that had some teeny tiny micro edges, those can get in the way of joining. So I needed to reconstruct some places around those.
