Full Version: V5 beta Feb-8-2025 available now (Sticky)
Show messages:  1-6  7-26  27-30
24 Mar   [#27] In reply to [#25]
Hi Frederick, for setting the name of the group at creation time, I've attached an alternate group command that will do that.
Instructions for installing a plug-in here.
You would set up a shortcut key with GroupSetName as the command name to run this one instead of the regular Group command.
GroupSetName.zip
24 Mar   [#28] In reply to [#26]
Thanks for the reply.
Creating the shortcut key works just fine.
And adding multiple objects to a group via selection works just fine too.
As to not asking for the name of the group when creating it - since I never used any of those other programs I was not aware of the "normal" behavior.
Just the same your program is so unique and incredibly good perhaps you can lead the way to a "better" approach.
Frederick
24 Mar   [#29] In reply to [#27]
You are just an amazing person.
The things you can make MoI do are incredible and very welcome.
Frederick
24 Mar   [#30] In reply to [#1]
I have found that when working on projects, when it comes to import/export I am mostly:
- importing from my "models" folder - where I keep the models that are used in the projects
- exporting to my "exports" folder the STLs that are used for printing
So it would be handy to have a way of specifying default folders for import and export - possibly with the option to specify different export folders for different types of things being exported (STL, 3DM, etc.)
Just an idea.
Frederick
