Full Version: V5 beta Feb-8-2025 available now (Sticky)
Show messages:  1-3  4-23  24-30
6 Mar   [#24]
You must draw the helper lines then call the script !!!
So when you change your function draw the Helper lines then recall the script
so you will have all the helper Lines of all functions ! :)
You have also this one by Paul (in English! ;)
slightly different : run the script - draw some helpers Lines (in the script itself) - click in empty space -
call a function Draw (with also its own helper if wanted ...these will be not saved) etc..
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.1k
All lines are kept, erase last one, erase all are also possible!
You can also rename and color like a layer technic (but color will be not visible but effective if hide "red" selection!) any moment ! (so hide some named selections)
( change color is not shown here)
23 Mar   [#25] In reply to [#1]
Some thoughts on V5
- cursor change on more of the long running operations - like grouping
- an easier way to activate the grouping operation on selected items - when far down in the list of objects and a few have been selected, scrolling all the way to the top is not much fun
- perhaps ask for the group name at time of creation
- so far I have no found a way to move more than one item at a time into an existing group
That is all for now - I will continue to test
Frederick
23 Mar   [#26] In reply to [#25]
Hi Frederick, thanks for testing it!
for this one:
You can go to Options > Shortcut keys , push "Add" and set the Key to something like Ctrl+G and for the "Command" part put in Group.
The grouping mechanics are modeled after the behavior of groups in 2D vector drawing programs. The typical behavior (like in Affinity Designer, MS Office, Inkscape) is to automatically name the group and not ask for the name at creation time.
You can do it by selection - select the multiple objects you want to move and right click on the name of the existing group (or left click on the existing group and choose "Assign selection here").
The "Move" menu item lets you move an object to a group without needing to set up object selection first.
24 Mar   [#27] In reply to [#25]
Hi Frederick, for setting the name of the group at creation time, I've attached an alternate group command that will do that.
Instructions for installing a plug-in here.
You would set up a shortcut key with GroupSetName as the command name to run this one instead of the regular Group command.
GroupSetName.zip
24 Mar   [#28] In reply to [#26]
Thanks for the reply.
Creating the shortcut key works just fine.
And adding multiple objects to a group via selection works just fine too.
As to not asking for the name of the group when creating it - since I never used any of those other programs I was not aware of the "normal" behavior.
Just the same your program is so unique and incredibly good perhaps you can lead the way to a "better" approach.
Frederick
24 Mar   [#29] In reply to [#27]
You are just an amazing person.
The things you can make MoI do are incredible and very welcome.
Frederick
24 Mar   [#30] In reply to [#1]
I have found that when working on projects, when it comes to import/export I am mostly:
- importing from my "models" folder - where I keep the models that are used in the projects
- exporting to my "exports" folder the STLs that are used for printing
So it would be handy to have a way of specifying default folders for import and export - possibly with the option to specify different export folders for different types of things being exported (STL, 3DM, etc.)
Just an idea.
Frederick
