Full Version: Flatten curves
Show messages: All  1-4  5-10
28 Jan 2025   [#5] In reply to [#4]
Hi Matadem, with that method watch out for gaps between pieces. Pepakura designer is more meant to handle low polygon output where you are going to fold paper along poly edges.
But it looks like it's handling your case as a larger developable surface ok.
7 Mar 2025   [#6] In reply to [#4]
As Michael mentioned Rhino is great for very accurately unwrapping surfaces. I've designed complex tube notched structures, unrolled the tubes, and used a cricket cutter to create full size templates. Everything fit perfectly in the real world and welded up nicely. It's amazing to have the ability to create a complete set of templates and jigs in moi3d that translates into a perfect fit in steel.
7 Mar 2025   [#7]
Yep hopefully Moi will get this feature in the future.
Because I use Moi for everything lol....from paper to metal, from concept to reality :D
7 Mar 2025   [#8]
You have FormZ Free for Unfold! ;) (FormZ to Moi in step
Minute 24.10 That was Version 9, totay it's V 10 ;)
8 Mar 2025   [#9] In reply to [#6]
Hi Craig,
Thanks for sharing your template technique. That is pretty cool!
- Peer
13 Mar 2025   [#10] In reply to [#9]
Your welcome! I had a blast figuring it out and was happy to find that it worked well. Looking forward to using it on a larger scale project.
