Full Version: COOL ! Blender Import/Export add-on
Show messages: All  1-8  9-18
23 Jan   [#9] In reply to [#8]
Hi, Michael...
it's : C:\User\%username%\AppData\Local\Temp
I'm using windows 11, by the way.
Thank you for the fast respond.
23 Jan   [#10] In reply to [#9]
Hi Elang, your Temp folder looks fine.
If you create a folder named BMOI inside %temp% does it then work ok?
It appears that you need to run the blender plugin once first before you use the MOI side so that sub-folder inside the temp folder will get created.
27 Jan   [#11]
Here's a version that should work on Mac.
The install is mostly the same as on the main page:
https://github.com/TitusLVR/BMOI_Connector
You put the MOI scripts under ~/Library/Application Support/Moi/commands and ~/Library/Application Support/Moi/startup
and the Blender script goes under ~/Library/Application Support/Blender/<BlenderVersion#>/scripts/addons/BMOI_Connector/__init__.py
EDIT: updated Mac version to put temp files directly in /tmp instead of in subdirectory since some on some OS versions there are permission issues with writing to the subdirectory.
BMOI_Connector.zip
28 Jan   [#12] In reply to [#11]
Thanks Michael.
28 Jan   [#13] In reply to [#5]
Sorry in the delay in replying but it appears Mr Gibson posted the link.
Ken
29 Jan   [#14] In reply to [#11]
For Blender it's OK but for MoI on my MacBook M2 pro it's not.
There are 3 files in each folder?
03 - 05 after I open MoI.
Marek
29 Jan   [#15] In reply to [#14]
Hi Marek, there are 3 files to put in the commands folder and 1 file to put in the startup folder.
When the .zip file is unzipped, there will be 3 files inside MOI3D/Commands - "bmoi_export_FBX.js", "bmoi_Import_OBJ.htm", "bmoi_Import_OBJ.js".
These 3 go into ~/Library/Application Support/Moi/commands like you show. These should not go into ~/Library/Application Support/Moi/startup so remove them from there.
The 4th file to copy is "97 BMoi.js" in the .zip file under MOI3D/startup - this is the one to put in ~/Library/Application Support/Moi/startup , this is what makes the buttons show up in the bottom toolbar.
When you do the export from MOI you need to select the objects that you want to transfer. If you don't then the "Nothing is selected" error will show.
29 Jan   [#16] In reply to [#15]
Sure enough, now all is fine after following your answer.
Thanks a lot.
Marek
30 Jan   [#17] In reply to [#15]
Updated Mac version attached above:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11634.11
Updated Mac version to put temp files directly in /tmp instead of in subdirectory since some on some OS versions there are permission issues with writing to the subdirectory.
27 Mar   [#18] In reply to [#17]
Love this plugin. It is a must have.
