Full Version: COOL ! Blender Import/Export add-on
Show messages: All  1-2  3-18
18 Jan   [#3] In reply to [#2]
Here is the link in the MOI forum where Frenchy Pilou posted the link. Looks like it was from github. I recalled installing it but had forgotten all about it. Works great.
Check the MOI <> Blender thread at your MOI Forum for info. Sorry but when I post a link to the thread it does not open the thread, only the Discussions room.
SO I posted a reply in the original MOI <> Blender thread to make it current.
https://moi3d.com/forum/index.php?webtag=MOI
So is it a script, add-on, pug-in? And what is the difference between the three (if any) ?
Also shown are the two other options to bring an OBJ into MOI3D "subdiv",and "impObj". I find the BMOI add-on superior to the other two options. Never get any satisfactory results with either.
18 Jan   [#4] In reply to [#3]
Hi Ken,
> So is it a script, add-on, plug-in?
Those are all more or less the same thing. You could call it any one of those.
22 Jan   [#5] In reply to [#3]
Hi KENMO,
I'm interested in this. Could you please point to the right link?
(because your current link brought us to the forum index instead)
Thank you very much in advance.
22 Jan   [#6] In reply to [#5]
@Elang, I think this is it:
https://github.com/TitusLVR/BMOI_Connector
23 Jan   [#7] In reply to [#6]
Thank you very much, Michael.
Edit:
I can't get both import and export to work:
- the export throws 'Error writing file'
- the import shows (an instantly closed) UI which says : "Joining. Press ESC to skip"
I'm using the still running V5 beta
23 Jan   [#8] In reply to [#7]
Hi Elang,
It says:
quote:
System requirements:
Windows 10
Windows 10 temp folder location must be by default
What is your temp folder location? If you press Win+R and put in %temp% what location opens?
23 Jan   [#9] In reply to [#8]
Hi, Michael...
it's : C:\User\%username%\AppData\Local\Temp
I'm using windows 11, by the way.
Thank you for the fast respond.
23 Jan   [#10] In reply to [#9]
Hi Elang, your Temp folder looks fine.
If you create a folder named BMOI inside %temp% does it then work ok?
It appears that you need to run the blender plugin once first before you use the MOI side so that sub-folder inside the temp folder will get created.
27 Jan   [#11]
Here's a version that should work on Mac.
The install is mostly the same as on the main page:
You put the MOI scripts under ~/Library/Application Support/Moi/commands and ~/Library/Application Support/Moi/startup
and the Blender script goes under ~/Library/Application Support/Blender/<BlenderVersion#>/scripts/addons/BMOI_Connector/__init__.py
EDIT: updated Mac version to put temp files directly in /tmp instead of in subdirectory since some on some OS versions there are permission issues with writing to the subdirectory.
BMOI_Connector.zip
28 Jan   [#12] In reply to [#11]
Thanks Michael.
28 Jan   [#13] In reply to [#5]
Sorry in the delay in replying but it appears Mr Gibson posted the link.
Ken
29 Jan   [#14] In reply to [#11]
For Blender it's OK but for MoI on my MacBook M2 pro it's not.
There are 3 files in each folder?
03 - 05 after I open MoI.
Marek
29 Jan   [#15] In reply to [#14]
Hi Marek, there are 3 files to put in the commands folder and 1 file to put in the startup folder.
When the .zip file is unzipped, there will be 3 files inside MOI3D/Commands - "bmoi_export_FBX.js", "bmoi_Import_OBJ.htm", "bmoi_Import_OBJ.js".
These 3 go into ~/Library/Application Support/Moi/commands like you show. These should not go into ~/Library/Application Support/Moi/startup so remove them from there.
The 4th file to copy is "97 BMoi.js" in the .zip file under MOI3D/startup - this is the one to put in ~/Library/Application Support/Moi/startup , this is what makes the buttons show up in the bottom toolbar.
When you do the export from MOI you need to select the objects that you want to transfer. If you don't then the "Nothing is selected" error will show.
29 Jan   [#16] In reply to [#15]
Sure enough, now all is fine after following your answer.
Thanks a lot.
Marek
30 Jan   [#17] In reply to [#15]
Updated Mac version attached above:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11634.11
Updated Mac version to put temp files directly in /tmp instead of in subdirectory since some on some OS versions there are permission issues with writing to the subdirectory.
27 Mar   [#18] In reply to [#17]
Love this plugin. It is a must have.
