2-21
22-41
42-61
62-81
82-101
102-121
122-141
@MO_TE
Perfect : i will use the "Full" one next time! ;)
And "ToolTips" of course! :)
Ps ToolTip help also to understand the Node name istself for the translation! ;)
Yes, the issue is solved! Tanx for checking on me!
-Psygorn
Hi
Check out the new version :)
Added node tooltips translation support. ( See the "lang.js" file under core folder )
Added "swRotary" widget by Brian. ( I moved the code to "interface.js" file )
Added two new modes for "ConvertPts" node by Brian.
Fixed "note" node
Added "printDict" function to "main.js" file for extracting and formatting NE words.
Hello and thanks a lot for this huge work!
I’ve got to say, I’ve been wondering about something.
Has anyone here heard anything about the legendary Mr. Max Smirnov? It’s been years since he’s been active on the forum. Does anyone know if he’s even still alive? I’m serious, no joke.
Obviously, I don’t know him personally and never had the chance to meet him. I only know the incredible work he did here years ago, creating the amazing and super-powerful “Nodeeditor.”
That tool gave a huge boost to “Moi 3D,” which, honestly, feels pretty stagnant these days because of its painfully slow development pace—though it’s still one of the best 3D editors out there, no question.
I think we all owe Mr. Smirnov a lot of gratitude for what he created (not to mention all those incredible scripts he shared).
So yeah, I’m just wondering—has anyone heard anything about him?
Thanks! :)
Hi Marco, last contact with Max was in June 2022, he's ok and he confirmed that his scripts are open source under the MIT license.
“Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.”
― Antoine de Saint-Exupéry, Airman's Odyssey
IMO MoI sw represents this philosophy perfectly, and is therefore becoming an increasingly preferred CAD modelling sw for transforming a fleeting moment of inspiration into reality :-)
Mik
Thank you, Michael, for this update regarding Mr. Smirnov.
So, does this mean you haven’t heard from him since 2022, or when you say “he’s ok,” are you referring to the present?
Either way, it’s truly a great loss that he stopped developing the “Nodeeditor” and all the other marvellous tools he created for this software and community.
Allow me to reiterate something I wrote on this forum quite some time ago.
By creating “Moi 3D,” you gave us a truly EXTRAORDINARY piece of software in so many ways (though I must admit the development updates do feel frustratingly slow).
Then, Max Smirnov took that software and brought it close to perfection.
From my perspective, there’s a “Moi 3D” before Max Smirnov and a “Moi 3D” after Max Smirnov.
All the best, and wishing you well. :)
Hi Marco,
I haven't heard from him since June 2022 which was a while after he removed all his stuff from the forum. He was doing ok at that time.
Does the Tooltips function is yet effective ?
I have only the first line when i make the Alt Click on a node!
EDIT : Ok found the trick... it was just a "," somewhere ! O:)
Very smart!
But Now hundreds to make! :)
@ Mo_ te
Here the second draft of the "complete" French Nodes! Tooltips
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_save02.js
Seems a miracle but all seems works like a charm !
Of course some cosmetic corrections must be made... for that i must re-read all nodes and ToolTips! ...
Not a speedy work! :)
I have used your toolstips list but not with not the same "number lines" because i had mine yet made with other nodes :)
If you make some new things put them in some new embeded lines... :)
So i made a little cooking Copy Past between the codes of the Lang files.
And some cosmetic corrections like this must be done! :)
Ok Michael.
Thanks for the info.
Have a nice day.
Hi PILOU
It looks great! Thanks for your contribution. :)
It's ok if translated descriptions are shorter or longer in length. You can write any description with any length. It'll fit in the tooltip box automatically.
>> I f you make some new things put them in some new embeded lines... :)
>> So made a little cooking Copy Past between the codes of the Lang files.
Ok, but, I think it is almost a complete list of words.
Yesterday, I improved the searchbox, So, You can search nodes in your language.( EN, FR, RU )
It doesn't need any additional translation. :)
@Mo_Te
Super!
I have a little problem
the 2 "Entrée" & "Sortie" on the Macro section don't give any nodes!
Does this normal ?
EDIT : OK I have Found!
I must "open" the Node Macro first (then Clik on it ) !
Solution of the little problem! ;)
Yes, "Macros/Input" and "Macro/Output" nodes are only available in "Macros/Container" (Macro).
Many corrections to the French lang.js :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_save03.js
Hi, you have made some wonderful improvements. One thing I would love is a check box on the output node to enable or disable it. I usually have several output nodes and often want to turn them on or off to focus on different parts of the model. Sometimes I just disconnect them for simple models but for more complex models I usually add a switch node before all outputs which solves the problem but I feel an integrated solution would be better.
Hi
Actually, This is an existing feature inside the NE Plus, (Embedded widgets)
But, I haven't used it in an actual node yet. Except inside some widget nodes.
Find "Widget/Widget Examples" node to see some examples of embedded widgets.
If you want to study the code, see the "EmbeddedWidgets.js" under "NodeEditorPlus\nodes\extensions"
Here is a quick attempt to add a toggle for enabling or disabling the output node.
I haven't tested it correctly, but, it seems to work ok.
Replace attached file with "objects.js" file in the "nodes" folder.
Let me know if you find it useful.
objects.js
I'm getting an error message:
NodeLibrary.cfg.htm not found!
What have I done wrong?
Thanks.
Frederick
Windows or Mac?
This .htm file has one code line, an address: Node Library;MOI\NodeEditorPlus\NodeLibrary
and may be located for Windows 11 at C:\Users\...yourFileAddressName...\AppData\Roaming\Moi\NodeEditorPlus\core\NodeLibrary.cfg.htm
Hi Frederick,
Does the error happen immediately when you launch the node editor or does it happen when you use something in particular?
What version of MOI are you using and what is your operating system?
Also where have you installed the node editor?
2-21
22-41
42-61
62-81
82-101
102-121
122-141
