74-93
94-113
114-133
134-141
I will test in 10 minutes !: )
What is the use of the "I" up side right up page ?
It's the "Properties panel" or "
Info panel" toggle to turn the panel on or off.
OK!
Ai don't succes to use .nod to manage some numerical numbers inside yet existing scripts!
Whitout a big transformation of the script itself! :)
So I will stay in pure nod (without draw nodes) for some cool other things :)
Next will be a pure geometric drawing! :)
So...
You can select anything! And multiple! :) Lines, curves, surfaces, volumes...
Always no drawing nodes! :)
https://moiscript.weebly.com/elephantia.html
@ MO_TE - A little request : make the possibility to have a "step" inside sliders ? (maybe yet existing...)
Hi PILOU,
Here are the "Knob" and "Slider" nodes with step property added.
Please check the attached file. Put it under "moi\NodeEditorPlus\nodes" folder and replace it with the older file.
I'll add it to the next release if everything works well.
interface.js
@ Mo_TE
Perfect il will try that as soon possible!
@ MO_TE
Seems excellent! Bravo!
74-93
94-113
114-133
134-141
