Full Version: NodeEditor Plus [Unofficial]
Show messages:  1-12  …  73-92  93-112  113-132  133-141
28 Sep   [#133] In reply to [#132]
>> I believe there is not more simple to add some nodes from NodeEditorPlus inside the plugin it self ?
I have some ideas for automatically generating nodes as you work in MoI, but that will take some time to implement. Until then, they will need to be added manually.
28 Sep   [#134] In reply to [#133]
I will test in 10 minutes !: )
What is the use of the "I" up side right up page ?
28 Sep   [#135] In reply to [#134]
It's the "Properties panel" or "Info panel" toggle to turn the panel on or off.
28 Sep   [#136] In reply to [#135]
OK!
Ai don't succes to use .nod to manage some numerical numbers inside yet existing scripts!
Whitout a big transformation of the script itself! :)
So I will stay in pure nod (without draw nodes) for some cool other things :)
30 Sep   [#137]
Next will be a pure geometric drawing! :)
1 Oct   [#138]
So...
You can select anything! And multiple! :) Lines, curves, surfaces, volumes...
Always no drawing nodes! :)
https://moiscript.weebly.com/elephantia.html
@ MO_TE - A little request : make the possibility to have a "step" inside sliders ? (maybe yet existing...)
2 Oct   [#139] In reply to [#138]
Hi PILOU,
Here are the "Knob" and "Slider" nodes with step property added.
Please check the attached file. Put it under "moi\NodeEditorPlus\nodes" folder and replace it with the older file.
I'll add it to the next release if everything works well.
interface.js
2 Oct   [#140] In reply to [#139]
@ Mo_TE
Perfect il will try that as soon possible!
3 Oct   [#141] In reply to [#139]
@ MO_TE
Seems excellent! Bravo! https://moiscript.weebly.com/elephantia.html
