69-88
89-108
109-128
129-141
Of course now with any object you can make parametric Transform Array ! :)
Will be the next exercice! :) (for the Ai! ;)
But i make a little wait because today there is a new version Nano Banana (2.5) who must be released!
So servers are some perturbated! :)
@ MO_TE
Seems you have forgotten to answer to my previous post! :) (with numerous little questions :=)
Here my new, this time without any problem! :)
What is a base and target Frame for this one ?
next will be with a script! :)
Here the Array Grid
Of course didn't draw any knots !!!
https://moiscript.weebly.com/elephantia.html
Can be a time saver in numerous cases! :)
Hi PILOU,
My apologies for the delay; I overlooked your question.
So, here it is, I hope I understand the questions correctly.
To use the objects from the moi viewport, node editor provides 3 nodes:
A: Select/Select Scene Objects
Select the object in the viewport, right click on the node and click on "Update". You can clear the selection by clicking on "Clear".
B: Select/Select By Style
Selecting the node opens a property panel, Choose the desired styled object from "Style" dropdown menu.
C: Select/Select By Name
Selecting the node opens a property panel, Choose the named object from "Name" dropdown menu.
>> why the reduce size of the close window (-) to the task Barre is not working ?
It seems moi disables the dialog's minimize button by default. However, You can resize the window to a smaller size.
>> Have you something for enable Acis / Solid++ ?
I'll add a new "Library" property in the fillet node.
>> Zoom fit the Screen Editor ?
Press the F key to fit the view to the selected nodes or fit to all nodes if nothing is selected.
>> Clear All Nodes ?
Click and hold the "New" button.
>> And how to keep the result ? (In fact exit of NodeEditor without lost result)
Click the "Apply" button to add the geometry to the scene.
>> What is a base and target Frame for this one ? (Array3D node)
This is an older node ported from Max Smirnov's "Array3D" command, so I may be slightly off. However, I believe the Base and Target frames override the Move X, Y, and Z node inputs. This is useful if you need to move or rotate the input object relative to a specific point.
@ MO_TE
No Problem !
Many thx for all these infos! (added to my little site :
https://moiscript.weebly.com/elephantia.html ;)
My next try will be to Use NodeEditor Plus inside a plugin!
I believe there is not more simple to add some nodes from NodeEditorPlus inside the plugin it self ?
I have some ideas for automatically generating nodes as you work in MoI, but that will take some time to implement. Until then, they will need to be added manually.
I will test in 10 minutes !: )
What is the use of the "I" up side right up page ?
It's the "Properties panel" or "
Info panel" toggle to turn the panel on or off.
OK!
Ai don't succes to use .nod to manage some numerical numbers inside yet existing scripts!
Whitout a big transformation of the script itself! :)
So I will stay in pure nod (without draw nodes) for some cool other things :)
Next will be a pure geometric drawing! :)
So...
You can select anything! And multiple! :) Lines, curves, surfaces, volumes...
Always no drawing nodes! :)
@ MO_TE - A little request : make the possibility to have a "step" inside sliders ? (maybe yet existing...)
Hi PILOU,
Here are the "Knob" and "Slider" nodes with step property added.
Please check the attached file. Put it under "moi\NodeEditorPlus\nodes" folder and replace it with the older file.
I'll add it to the next release if everything works well.
interface.js
@ Mo_TE
Perfect il will try that as soon possible!
@ MO_TE
Seems excellent! Bravo!
69-88
89-108
109-128
129-141
