Full Version: NodeEditor Plus [Unofficial]
Show messages:  1-11  12-31  32-51  52-71  72-91  …  132-141
22 Dec 2024   [#12] In reply to [#10]
Thanks Michael :)
22 Dec 2024   [#13] In reply to [#11]
Thanks MO,
Here at home, still on Windows 10.
I'll try it at work tomorrow, (Windows 11).
Thank you very much for this new nodeeditor.
22 Dec 2024   [#14] In reply to [#6]
> The shortcut resizable window setting of the new version does NOT seem to work.
Is there any error message displayed?
If you get an error dialog that says "ReferenceError: Can't find variable: theme" then it probably means you only got the last line (starting with "moi.ui.createDialog") copied, make sure you copy all 3 lines.
22 Dec 2024   [#15] In reply to [#6]
for this part:
> Edit upon closing and re-opening MoI, the New shortcut key is no longer installed
> (assigned new code)...so it does not work.
This can happen if you have multiple instances of MoI running when you set up a new shortcut key.
MoI will save shortcut keys to the moi.ini file when it exits, and if you exit an instance that did not have the shortcut key set in it last it will get overwritten.
So it's good to have only one instance of MoI running when you are setting up shortcuts, and then close that one before you open up any more.
I've tuned this up a bit for the next beta so that it will write changes to the moi.ini immediately after editing any shortcuts. You should still have only one instance running but you won't need to close it to get moi.ini to be updated.
22 Dec 2024   [#16] In reply to [#14]
I have tried numerous permutations of changing the Shortcut key. Including Alt+T, Ctrl+Alt+T, Ctrl+Alt+X, and rebooting the computer.
Setting Alt+T to my modified code, I am able to get Light, and Lavender.
For the PDF specified shortcut code, I am now "stuck" on default dark theme, but with the large canvas. A while back the canvas size was remaining small.
Setting Ctrl+Alt+T to the PDF specified shortcut code, with copy & paste, numerous times, and changing the Default theme to Light, or Lavender, etc, does NOT change from default Dark.
After a reboot, the canvas display is delayed, with a very brief flash of light color.
It is almost like there is a Cache of the default dark theme, but reboot should end this. (?)
(I was able to change the default language to FR, with no problem.)
Anyway, weird stuff. (Windows 10)
I do have the recent new alternate Themes installed, but am not using them.
Is anyone else having NodeeditorPlus Theme problems?
22 Dec 2024   [#17]
Theme problem SOLVED!
I was copying the shortcut command from a PDF program which opened the NEPlus document PDF file.
Apparently the PDF program put in some BAD characters of some sort.
So copying the shortcut code from MO's code on the MoI discussion worked fine.
I think that the PDF reader program was from MS Edge(???)
22 Dec 2024   [#18] In reply to [#17]
With further testing, I'll conclude that "Copying the Shortcut code from the PDF documentation via Edge, Google chrome, or Adobe does NOT work properly, even though the characters visually appear correct.
Copying from the MoI forum works.
I suppose that typing the pdf code manualy would probably work.(?)
22 Dec 2024   [#19] In reply to [#18]
I'm glad you got it figured out Brian!
23 Dec 2024   [#20] In reply to [#8]
Hi Mo,
Perhaps the option to toggle on and off the time elapse could be added to the node menu?
Barry
23 Dec 2024   [#21] In reply to [#20]
Hi Barry
It is possible, but I think It's not something that we need to access all the time in a menu.
I'll think about it.
23 Dec 2024   [#22]
After separately copying the 4 shortcut code lines from the Documentation PDF, to Notepad++, and removing the CR and/or LF (Carriage Return, Line Feed), at the ends each code line, by backspacing, I have reached the following conclusion:
The Documentation PDF shortcut code contains several CR and/or LF, which if copied to the shortcut key, cause the shortcut code to fail.
I would suggest changing the PDF to not create CR and/or LF, (if possible), OR add a text file of the shortcut code, to the NodeEditorPlus zip file, and tell the user NOT to copy/paste original PDF code.
Edit: CR and/or LF can be removed in Notepad++, (find and replace), per internet searches.
I am now done with this shortcut topic :-)
23 Dec 2024   [#23] In reply to [#22]
Thanks for mentioning it. I can see it now.
The problem was at the end of the third line. I should have concatenated the 3rd and 4th lines in the pdf.
var theme = 'Default'; /* Theme options: Default,Light,SkyBlue,Autumn,Lavender */
var language = 'EN'; /* Language options: EN,RU,FR */
moi.ui.createDialog( 'moi://appdata/NodeEditorPlus/index.html?'+
'scheme='+theme+'&lang='+language+'', 'resizeable,defaultWidth:870,defaultHeight:480',
moi.ui.mainWindow );
The code in my first post works fine, I'll update the pdf soon.
Sorry for inconvenience.
23 Dec 2024   [#24] In reply to [#23]
Cool MO!
Thank you again
24 Dec 2024   [#25]
Hi all,
I will prepare a french version of the documentation.
25 Dec 2024   [#26] In reply to [#25]
Excellent i will put a link to my French site!
25 Dec 2024   [#27]
Hi MO,
It is great to see a reboot of the Node Editor for MoI!
Thank you!
Wayne
25 Dec 2024   [#28]
Hi
Just uploaded new version
v0.7.01 Updates:
Fixed pdf shortcut code issue
Added CTRL + Double click on canvas to toggle "canvas info" on and off
25 Dec 2024   [#29] In reply to [#25]
Hi Phiro
Thanks for your contribution :)
26 Dec 2024   [#30]
Hi all,
A french version of the documentation.
Have fun !
P.
NodeEditorPlus_Quick Start-FR.pdf
26 Dec 2024   [#31] In reply to [#30]
Bonjour Phiro
Thank you for your contributions... which make this software magical and a forum rich with great people.
Merci pour vos contributions ... qui rendent ce logiciel magique et un forum riche de belles personnes.
chri
