Full Version: NodeEditor Plus [Unofficial]
Show messages:  1-5  …  46-65  66-85  86-105  106-125  126-141
1 Jan   [#106]
@MO_TE
Does the tooltips are yet ready in the English Version and how to see them on the screen of NodEditorPlus?
something to enable ?
Because seems to see them in orange previously!
Another thing : does i must Copy Past lines 2983 - 4157 and put FR
then Translate
or just change EN to FR line 2983 ?
then translate ?
1 Jan   [#107] In reply to [#106]
Thank you for your contribution to the French translation.
Node tooltips are accessible via holding Alt and left-clicking on the node.
>> do i must Copy Past lines 2983 - 4157 and put FR
>> then Translate
You can leave them as they are; They are not for translation. thank you.
1 Jan   [#108] In reply to [#107]
THx for the Infos!
1 Jan   [#109]
Yep but i can make that! ;)
Ps Seems thats working also fine with the French version !
1 Jan   [#110]
You right all is yet fine i don't know why! :) (French Tooltips also) D:)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
1 Jan   [#111]
For a little test... transform a cube to a pyramid ... as the direct generation of the file don't yet works
Here the manual method not sure that really help! :)
1. Create the Base Shape ... Add a Curve/Rectangle node.
Set Width to 20 and Height to 20.
This represents the footprint of your shape on the ground.
2. Elevate the Top Profile... Add a Transform/Move node.
Connect the Rectangle output to the Objects input of the Move node.
In the Translation field, set the Z value to 30 (format: 0,0,30). This defines the height.
3. Control the Taper (The "Magic" Step) ...Add a Transform/Scale node.
Connect the Move output to the Objects input of the Scale node.
Crucial: Set the Center of the Scale node to 0,0,30 (the same height as your moved square).
Add a Basic/Slider node. Set its range from 0.0 to 1.0.
Connect the Slider output to the Factor input of the Scale node.
Slider at 1.0 = Cube
Slider at 0.0 = Pyramid
4. Group the Profiles... Add a Logic/BundleArray node.
Connect the original Rectangle (from Step 1) to In 1.
Connect the Scale output (from Step 3) to In 2.
This creates a list containing both the bottom and top squares.
5. Generate the Volume...Add a Construct/Loft node.
Connect the BundleArray output to the Profiles input.
MoI3D will now stretch a "skin" between the two squares.
6. Final Output... Add a Basic/Output node.
Connect the Loft output to it to see the final geometry in the MoI3D viewport. ...
Quick Tip: If you want the pyramid to be "solid" (a closed BREP),
make sure to check the "Cap ends" option if it's available in your version of the Loft node, or use a Solid/PlanarSrf on the result.
Curious result ... but surely schematic
1 Jan   [#112]
a node Object / Selected don't exist anymore ?
Waiting more something like that! :)
But not yet tested because it's while i don't touch this sort of thing!
But terrific if you can ask an Ia to make for you anything you want without knowledge of Nodes!
Maybe not today at 100% but surely after tomorrow!
2 Jan   [#113]
Generating an object in NodeEditor is quite similar to how it's done in moi, but with parametric capabilities.
Here are two simple methods to generate a pyramid.
This node has been relocated to the "Select" menu, under the title "Select Scene Objects". It's also accessible in the search box.
2 Jan   [#114] In reply to [#113]
Excellent! Where is the Search Box ? (how to call it ?
Center ?
2 Jan   [#115] In reply to [#114]
Double-click on the canvas (NodeEditor window) :)
2 Jan   [#116] In reply to [#115]
That is wortking!
3 Jan   [#117]
Great Work MO!
// Rich
15 Jan   [#118] In reply to [#1]
Hi Mo,
been playing with your unwrap curve / surface node.
Have you an example as getting shapes that need scaling so not sure I am using it correctly.
Barry
15 Jan   [#119]
Works as aspected! Sorry in French but...
Pinky curve is planar and has same length than green one!
It's the same for you ?
Curious! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/planar_curves.3dm
15 Jan   [#120] In reply to [#119]
this is why I am not sure if I am using it correctly.
The unwrapped in these cases are 1 x 1 but if scaled looks correct.
In others they are scaled correctly in one direction only.
Barry
23 Sep   [#121]
seems there is an error when i want copy a node...
23 Sep   [#122]
A long time to not use this sort of thing! :)
How to update an object to the node ?
say 3 different cubes are drawn : how to integrated them as 3 different nodes selected ?
23 Sep   [#123]
No Video like this for NodeEditor Plus ?
23 Sep   [#124] In reply to [#121]
Hi PILOU,
Thanks for reporting the issue.
I couldn't regenerate the error here, but if you're still getting this error, please post the .nod file, so I can take a look.
Could you tell me which method you used to copy the nodes that caused the issue?
1- Right clicking on nodes and copy
2- Pressing Ctrl key and dragging nodes
3- Using shortcut ( Ctrl+C )
You can use the "Concat" node under "General/Concat". ( See attached node )
Right click on the node to add more input slots via"Inputs " menu.
If you need to remove a slot, right click on the last input slot and select "Remove Slot".
Unfortunately, There is not much tutorial contents for Node Editor Plus right now.
Here are a few examples. I'll update it if I find more.
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11886.1
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11887.1
Concat Node.nod
24 Sep   [#125]
@ MO_TE
THx for the Infos!
No problem with your previous file .nod! :)
Fortunately, I kept my previous false one! :)
Same error with the 3 methods of copy on any of nodes!
It's a file generated by Ai maybe this explain that! ;)
Just ak you want and the Ai return a file Json format!
Just load it in a "text editor" and save it as a node file format .nod!
That is perfect for "normal people" like me because "Node coding" is not a so easy evident thing!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/inverse_fillet.nod
But as i don't now how even process with this new Node Editor Plus against the Official old original one by Max Smirnov... that i have quasi all documented... French / English ! ;)
https://moiscript.weebly.com/node.html
I can't help the Ai itself! :)
I am blocked how to select object(s) on the screen for integrate them on the Editor + ! :)
Given by the Ai !
In the Old you made Update! :) (as shown following... Golden Age ! :)
Ps Your Tab Library is a must for have some examples!
Render here with free Gemini
