Full Version: Polygon to Moi what are some best practices?
Show messages: All  1-5  6-20
9 Dec 2024   [#6] In reply to [#5]
Hello,
About this video with pieces coming from NVil and refined in MOI : what is the MOI feature used to align the small circular parts to the surface of the face, at 2h08 ? I just tried Orient (for the first time), but I can't seem to figure out how it operates.
Thanks !
9 Dec 2024   [#7] In reply to [#6]
“”””””” what is the MOI feature used to align the small circular parts to the surface of the face, at 2h08”””””
PastePart
If you want to kit bash, you can setup the part on 0,0,0 then copy it with Ctrl+C
Then pastePart as you describe.
9 Dec 2024   [#8] In reply to [#6]
Hi Pior,
One of: Orient ( if object is in the same file), PastePart ( Ctrl+Shift+V if object in clipboard ), or ImportPart ( Right click File > Export if object is in its own separate file).
There's some more info on Orient here:
http://moi3d.com/4.0/docs/moi_command_reference8.htm#orient
http://moi3d.com/forum/index.php?webtag=MOI&msg=3424.13
http://moi3d.com/forum/index.php?webtag=MOI&msg=3424.14
9 Dec 2024   [#9] In reply to [#8]
Excellent, thank you both !
I was confused by the order of operations of Orient, but the way PastePart skips the setup of the pasted element (inferring it from 0 0 0) clarified it. I now understand the first steps of Orient.
This is a very powerful workflow, partly bypassing the need to reorient the Cplane in case of freeform modeling. Very nice !
10 Dec 2024   [#10]
Maybe also sometime verify if the size of the import parts is at the good scale...
Depending of the progs used...
10 Dec 2024   [#11]
Another question...what about if it is not a sub D object?
Like just polygons and I want to bring it into Moi for let say Boolean operations?
Should it go thru meshmixer like Pilou indicated?
Tnx!
10 Dec 2024   [#12] In reply to [#11]
You have also the Obj23dmWireframe
http://moi3d.com/download/Obj23dmWireframe.zip
then you planar any selection you want...
10 Dec 2024   [#13] In reply to [#11]
Hi Matadem,
For non sub-D meshes, I would recommend to not try to import that type of data into MoI.
Generally it's better to edit polygon mesh data in a poly modeling program, not in MoI.
There may be exceptions for specific types of models, it would help if you would give an example file.
11 Dec 2024   [#14]
Not to hijack a thread, but I often find myself needing to import a polygon mesh into MoI just to use as a 3D reference. I'm often given 3D files by clients that I need to make a part to fit accurately in MoI, or to remodel the whole thing as NURBS, and currently there's no easy way to do this. It would be great for me if I could just import a polygon mesh even as a pretty much un-editable, otherwise useless object, just to use as a 3D reference for remodelling. There's only so much you can do (and so much accuracy you can achieve) with screenshots from each side, or extracted 2D curves imported from a polygon modelling software
Or I've modelled 2 parts of an object, one in Blender and one in MoI, that need to fit together and I just need to check fitment and scale etc
11 Dec 2024   [#15] In reply to [#14]
Hi DanC, for use as a visual reference you can use the OBJ23dmWireframe converter utility program, from here:
https://moi3d.com/wiki/Resources#Obj23dmWireframe_converter
That will convert an .obj file containing polygon mesh data into a wireframe .3dm file which can then be opened by MoI.
11 Dec 2024   [#16]
Good day..
I am working on something like this...not sub d
I was thinking of importing and perform exact booleans in Moi
I am still getting used to this kind of modeling...
12 Dec 2024   [#17] In reply to [#16]
Hi Matadem, if that's not sub-d then I would not recommend trying to bring it into MOI.
Your model data will be made up of a lot of little planar fragments.
If you then apply exact booleans your result will be a weird mix of a faceted main body and smooth only on the cuts you apply in MOI.
The main way that it could work would be if you constructed the body as a sub-d model in your poly modeling program. Then the main body would be a smooth surface in MoI after you convert it from sub-d.
12 Dec 2024   [#18]
Understood.
Thanks!
12 Dec 2024   [#19] In reply to [#15]
Thank you Michael, I'll check out that converter
15 Dec 2024   [#20]
For future reference and if I am not mistaken, here are the commands (some custom/third party) used in that video :
- "_importobj" (third party) to bring in a .obj control cage without subdivision. If it fails because of unsupported geo, subdividing the object once before import can bypass the issue.
- "_Subdiv_beta9" (also third party) to control the smoothness of subdivision
- "ImportSubD" (stock) to import a .obj with subdivision and reconstructed surfaces
- "pastepart" (stock) to place parts on surfaces.
For the third party import and subdivision scripts : https://moi3d.com/wiki/MaxScriptArchive
I hope this helps !
